Results 1 to 14 of 14
    Senior Member Two Rings PoVolks's Avatar
    May 12 2009
    15' Q5 TDI, 09' RS125, 04' GLI for $1k
    Atlanta, GA
    Banjo Extension d/s turbo?
    I've been slowly piecing an engine build together using spares, part-outs and other sources in an attempt to have a mostly assembled lump when the swap time finally comes, but man... If I could do it over again.?
    update: part number: 078145175B
    Does anyone have one of these sitting around? Or know of an alternative solution? The driver's side turbo has a spacer to raise the coolant supply line for clearance for the oil line. See pics, #8 in the diagram. Thanks
    May 12 2009
    Atlanta, GA
    Sent from my Pixel 7 Pro using Audizine Forum mobile app
    Veteran Member Four Rings V8Star's Avatar
    Jun 08 2010
    No longer available from Audi.
    I was going through the same deal earlier this year and found a used k03 turbo on eBay with all the fittings still attached. Luckily paid around $90 For the turbo which is only a few bucks more than what the fitting would have cost anyways
    Oct 12 2018
    B5 S4 Avant 2.7t 6MT
    Try ATP Turbo online catalog of turbo fittings & adaptors. Or search, female to male fitting with thread size. IIRC it's only a steel metric fitting and likely available outside of Audi parts.
    Sent from my Pixel 7 using Audizine Forum mobile app
    AKA: gjweyman
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Pretty sure The Tuner sells em
    May 10 2018
    MA
    Still gettable...but how urgently do you need it?
    May 12 2009
    Atlanta, GA
    I've got a guy locally that will check his stock pile, eventually. Also placed an order w/jhm for that part#. Got a confirmation email, but may be erroneously stated as available on their site.
    May 12 2009
    Atlanta, GA
    Quote Originally Posted by Silverex View Post
    They do, great looking out!
    Account Terminated One Ring
    Mar 07 2023
    Texas
    Quote Originally Posted by PoVolks View Post
    Where are you located??
    Veteran Member Four Rings belms4's Avatar
    Apr 17 2019
    2000 silver S4, 2001 imola S4, 2002 Avant nogaro RS4 conversion
    I got one too if you need it. Just lmk
    Sent from my SM-F721U1 using Audizine Forum mobile app
    May 12 2009
    Atlanta, GA
    Quote Originally Posted by alvisberry2 View Post
    I'm in the Atlanta area.
    May 12 2009
    Atlanta, GA
    Quote Originally Posted by belms4 View Post
    Thanks for the help belms4.
    Apr 17 2019
    Any time! Glad that got there quickly for you to use.
    As a side note, I think I'll order a small batch of these to keep stateside and sell out next time I place an order for THE parts.
    May 10 2018
    MA
    I have 30 of these coming in second week of May fwiw - genuine ones
