Originally Posted by
bakedziti
I didn’t realize that the Hotchkis setup also provided sway bar brackets but that’s a nice setup. It’s been a long time since I’ve looked at Hotchkis or this setup, but it appears there
may be some new old stock available below.
https://apikol.com/product/audi-b8-a...-set-hotchkis/
Hotchkis makes an incredible product. Sway bars are kinda their thing so it makes sense.
Appreciate you posting this. Immediately after buying my S4, scoured the web looking for some company that might still have a set. Last month ran across this and reached out to Apikol. Unfortunately they don't. Sad panda.
My previous experience with aftermarket end links felt like it made the rear too tight and squirrely, however was running some heavy Swift rear springs in that setup. What's your experience been like with them on the B8 platform?
Side note, now you've got me interested in the H&R bars. I see the front is adjustable... interesting. Stock the B8 S4's front end just flops all over the place, def needs some tightening up front.
WurstS4
I’ve read a few places, including one manufacturer/distributor page that doing the front bar winds up negating a lot of the improvement of the fatter rear bar, so to leave the front bar be. That throwing a thicker front bar in will tighten up the front and make the turn in even crisper, but will make the understeer the fat rear bar did away with, reappear.
Idk if that’s really the case, but I have read that in a few different places, and comments.
Respectfully, this couldn't be further from the case for our cars. Others yes, esp RWD setups but can't speak to that.
However for an understeering AWD German tank a proper set of sways will radically transform the vehicle's ability to destroy corners.
FWIW, I ran 4 or 5 different sway bar setups on the B6+7 and can overwhelmingly report that a matched set brought about the most significant performance upgrade.
To be clear, you're winning with whichever company you choose... H&R, 034 or EC all have great options with each one being a bit different than the others.
Related note, as luck would have it my S4 came completely stock... a blank canvas. Finally got to take it up on
Highway 9 at night for a proper test. Even bone stock, absolutely astounding. I can't really fathom what she'll be capable of with the addition of sway bars (and suspension). Def found the limits however that's more due to stock springs + right height. The Sport Diff does a lot of work during cornering which leads me to believe a softer sway bar setup will be more complimentary. So 034's on soft setting will be my setup.
