@Smac770
Update: Managed to get the hardware installed last week. As anticipated, all sorts of systems went offline due to the missing steering angle data, but the car was drivable and the steering controls, including heating, were fully functional. Had the local dealership reset the steering angle sensor and dynamic steering today. After the initial configuration work, the tech was kind enough to come and indicate an airbag fault was "sticky" and would require letting ODIS overwrite a bunch of data, which might likely impact the active TPMS system configuration (which I installed earlier this year). When he was done, he warned me there were now TPMS faults and drivetrain faults he thought related to the retrofitted TPMS system being misconfigured.
I brought the car home, reconfigured the active TPMS to the settings used when I installed it (a few had indeed been overwritten), and managed to eliminate the TPMS issue - warnings stopped and the display again worked. That said, the following warnings remain at startup:
- Speed control system: currently unavailable. See owner's manual
- Start-stop sytem malfunction.
- Drive system malfunction! Please contact service.
Here is a scan with a very limited number of error codes:
Code:
Chassis Type: F4-AU49 (80A)
Scan: 01 02 03 08 09 15 16 17 19 29 32 36 39 3C 42 44 46 47 52 5F
65 6C 74 75 81 A5 A9 BB BC CA CF D6 D7
VIN: WAUB4AF44KA119760 Mileage: 34930km-21704miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
29-Left Light -- Status: OK 0000
32-Differential Locks -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
39-Right Light -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
74-Chassis Control -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
81-Gear Shift -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CWGD) Labels:. 07K-907-309-V1.clb
Part No SW: 8W0 907 559 L HW: 06M 907 309 D
Component: V6 3.0l TFSI H22 0004
Revision: B2H22000 CVN: 8E0E8B32
Coding: 0A2A00322326010E34280000000000000000000000000000
Shop #: WSC 38815 003 1048576
ASAM Dataset: EV_ECM30TFS0118W0907559L 001004
ROD: EV_ECM30TFS0118W0907559L.rod
VCID: 4ECE0062B05A189ACD7-801A
VINID: 9D195211158411B4410491C6001BA51722
1 Fault Found:
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [167] - -
[Checking coding/versions ofcontrol modules in drivetrain]
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 34923 km
Date: 2023.10.18
Time: 17:34:31
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 72 C
Intake air temperature: 39 C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.880 V
Unlearning counter according OBD: 40
ACC variants-Bits 0-7: 0
CCS Switch-Bits 0-7: 2
Cruise control switch actuation-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 49
ACC variants (coding)-Bits 0-7: 1
Readiness: 0010 0101
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 8W0 927 158 C HW: 0D5 927 156 H
Component: 0D5 30TSIUSA H05 1006
Revision: --H05--- CVN: 09E32900
Coding: 100000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011_AU49.rod
VCID: 42D624527472ECFA59F-8116
No fault code found.
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 AF HW: 8W0 907 379 J
Component: ESP9 Plus H16 0777
Dataset Number: 8W0909504AA 0004 CVN: F66A9658
Coding: 1CAA149930A30A9F11A54897407D1292E5359A38280C508812024849A7AC59
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_004_AU49.rod
VCID: 0944F37E09C47FA2585-815C
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H60 0251
Dataset Number: 8W0909862D 0024
Coding: 1608050D5544000D10020100080000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ASAM Dataset: EV_AirCondiBHTCAU491 001013
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44DA224A6E66E2CA6B3-8110
Fresh air blower control module (front):
Subsystem 1 - Part No SW: 4M1 820 021 C HW: 4M1 820 021 C
Component: J126 FLuftV H09 0004
Serial number: 00000000000003931020
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: 9C719DB900PAG0MUFU02
Rear air conditioning block 1:
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 DG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0313
Dataset Number: 8W0909514P 0057
Coding: 07500363E0081CCD050D871518AC9CBB110B3D040000000000000000200016010A690122025705
Shop #: WSC 06325 790 00001
ASAM Dataset: EV_BCM1BOSCHAU736 019008
ROD: EV_BCM1BOSCHAU736_019.rod
VCID: 0358E1562BE825F2129-8156
Wiper motor control module:
Subsystem 1 - Part No SW: 8W1 955 119 A HW: 566 955 119
Component: J400FRWISCH 051 0822
Serial number: 887353F0401919102986
Coding: 7DC727
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 23338576X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AK HW: 4M0 941 531 AK
Component: E1 - LDS H06 0008
Serial number: 07 05 2019 01975874
Garage door opener control module:
Subsystem 4 - Part No SW: 4N0 907 410 C HW: 4M0 907 410 A
Component: USHL5 GX1 H12 0300
Serial number: 0000009600373Z00KJ02
Coding: 350000
Garage door opener control head:
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20190610095831 00348
Automatic dimming interior mirror:
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE104051924110362
Coding: 010000
Interior Light Module:
Subsystem 7 - Part No SW: 4K0 947 135 AS HW: 4K0 947 135 AS
Component: Dachmodul H42 0415
Serial number: B01272667
Coding: 0D0104
Control head for driving and comfort functions:
Subsystem 8 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 4919000074368003
Coding: 000000
Valve block 1 in front seat driver side:
Subsystem 9 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J873 MKS_FSv H03 0036
Serial number: 7008174235B192967411
Coding: BF0500
Valve block 1 in front seat passenger side:
Subsystem 10 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J872 MKS_BFSv H03 0036
Serial number: 7008174235B192967582
Coding: B30500
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 N HW: 8W0 959 655 N
Component: Airbag10.44 H09 0109
Serial number: 0030D000BXBS Dataset Number: 8W0909602AL 0002
Coding: BFCCF0C000800000A0000033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006.rod
VCID: 54FA120A9E06724AFB3-8100
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2040
Serial number: 8W0857705M0204T00437
Coding: 80000D
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2040
Serial number: 8W0857706P0206T00191
Coding: 80000D
Seat occupied recognition passenger side:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H12 0022
Serial number: IBH0000D19000BYI8V0%
Crash sensor for side airbag: driver side:
Subsystem 4 - Part No SW: ----------- HW: 442 060 507 19
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y00C530D5EB313A7
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 5 - Part No SW: ----------- HW: 442 062 706 19
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00BD30D5EB511EJ
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 6 - Part No SW: ----------- HW: 442 0B1 207 19
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700A332907D3B413
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 7 - Part No SW: ----------- HW: 442 0B1 207 19
Component: SideSensor_Pr 1C7 0148
Serial number: 3527700A332907D4A3AC
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 8 - Part No SW: ----------- HW: 442 0C1 107 19
Component: FrontSensor_D 1C5 014A
Serial number: 3557500AF331F4E4A21L
Coding: 2D2D2D
Crash sensor for front airbag: front passenger side:
Subsystem 9 - Part No SW: ----------- HW: 442 0C1 107 19
Component: FrontSensor_P 1C5 014A
Serial number: 3567500AD331F4E6818Q
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4N0 907 129 MJ HW: 4N0 907 129 MJ
Component: Lenks.Modul H03 0009
ASAM Dataset: EV_SMLSKLOAU736 007012
ROD: EV_SMLSKLOAU736_007_AU49.rod
VCID: 055CFF4E25DC1BC23CD-8150
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 890 E HW: 8W5 920 890 E
Component: FBenUSA H20 0417
Dataset Number: 8W0909525AB 0042
Coding: 09EF59C938A8CF050223E9641800400008000000
ASAM Dataset: EV_DashBoardAU736 001032
ROD: EV_DashBoardAU736_AU49.rod
VCID: 45DC3F4E655CDBC27CD-8110
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 80A 907 468 F HW: 80A 907 468 B
Component: Gateway H05 0207
Serial number: 1JF08063790201 Dataset Number: 8W0909515L 0070
Coding: 030100010000064054070000005900126C980007900000000175078E10000000
GVL: 01583C500000000040DC08008002C800110C0000000000000000000000000100
ASAM Dataset: EV_Gatew31xAU65x 003170
ROD: EV_Gatew31xAU65x_AU49.rod
VCID: 31347B9EC1D46762B05-8164
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 8W0 951 523 H HW: 8W0 951 523 H
Component: J453 MFL H04 0002
Serial number: 20170613010048 20050
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Component: J367-BDMHella H10 9070
Serial number: 4474571905
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
Component: LCM_MLBevoH05 0024
Dataset Number: 8W0909519B 0010
ASAM Dataset: EV_LCMLeftHELLAAU736 001012
ROD: EV_LCMLeftHELLAAU736_VW48.rod
VCID: 78A286BA622E762A37B-812C
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 HW: 8W0 907 163
Component: QSP QCU Gen2 H08 0060
Revision: 5WK12700 Serial number: 605930411200307
Coding: 0001
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_TVDCQSP22 001008
ROD: EV_TVDCQSP22.rod
VCID: 79A483BE59246F22485-812C
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0044
Serial number: 00000383770149 Dataset Number: 8W0909856C 0009
Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
ASAM Dataset: EV_SCMDriveSideCONTIAU736 006009
ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Dataset Number: 8W0909520B 0010
ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 F HW: 4M0 907 566
Component: MRR1Rear H22 0440
Revision: -------- Dataset Number: 8W0909535C 0020
Coding: 0E8002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
ROD: EV_RearRadarS1BoschAU736.rod
VCID: 382246BA22AEB62AF7B-816C
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 M HW: 4M0 959 793 J
Component: TSG FS 010 0384
Serial number: 0000373739524 Dataset Number: 8W0909872H 0034
Coding: 005F0B205200108000010032
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
VCID: 48C2367A524EC6AA87B-811C
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0410
Dataset Number: 8W0909852R 0043
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W1 907 064 AC HW: 8W1 907 064 C
Component: BCM2 MLBevo 044 0529
Dataset Number: 8W0909501N 0057
Coding: 013400004FB00080650FA0002C01000203004000810026502F0400000B04803F001E0001000010
ASAM Dataset: EV_BCM2HellaAU736 017017
ROD: EV_BCM2HellaAU736_017_AU49.rod
VCID: 7EAE90A2400A481A7D7-812A
Anti-theft alarm system sensor:
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY191800K55
Alarm horn:
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000047466946
Rear lid opener control module:
Subsystem 3 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0905
Serial number: 12222584
Address 47: Sound System (J525) Labels:* None
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAKJA066RCD Dataset Number: 8W0909510F 0018
Coding: 0194010800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
VCID: 76BE8882683A005A257-8122
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 4M0 959 792 M HW: 4M0 959 792 J
Component: TSG BFS 010 0384
Serial number: 0000374651986 Dataset Number: 8W0909873H 0034
Coding: 005F0B205E00108000010030
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
VCID: 47C035465F50C9D28E1-8112
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 880 E HW: 8W5 035 880
Component: MU-P-LNS-US 035 1316
Serial number: A798G0KB167141 Dataset Number: 8W0909545AM 0050
Coding: 019451020000000051220002041A00332F000AE401700904BE
Shop #: WSC 17873 123 50804
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 41D42B5E7174F7E2405-8114
Data carrier:
Subsystem 1 - Part No SW: V03 959 803 AM HW: -----------
Component: NAR 2022 --- 0085
Serial number: --------------------
Multimedia System 1:
Subsystem 2 - Part No SW: 8W0 919 605 HW: 8W0 919 605
Component: AU49x_DU_HIGH H40 0008
Serial number: AUZ8Z9KBJ06H5C
Multimedia system control head:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK117071900020311
Compact disc data bank:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 3013
1 Fault Found:
0020 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 26
Mileage: 34930 km
Date: 2023.10.18
Time: 18:06:02
Voltage terminal 30: 12.7 V
Satellite radio tuner status-Satellite radio antenna status: electrically OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: Not available
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Address 65: Tire Pressure (J502) Labels: 4M0-907-273.clb
Part No SW: 4M0 907 273 B HW: 4M0 907 273 B
Component: RDKHUFAU736 H06 0010
Serial number: 30000000256810 Dataset Number: xiaozhihui 0004
ASAM Dataset: EV_RDKHUFAU736 002007
ROD: EV_RDKHUFAU736.rod
VCID: 2F307DE6D7E07192A61-817A
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H18 0250
Dataset Number: 8W0909460B 0010
Coding: 0294010102002001400040
ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
VCID: 333871963BC85572C29-8166
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 8W0 907 777 T HW: 8W0 907 777 C
Component: Fahrwerk-SG H37 1215
Serial number: 2307191103 Dataset Number: 8W0909576N 0002
Coding: 1460484958
ASAM Dataset: EV_ChassContrContiAU426 001003
ROD: EV_ChassContrContiAU426.rod
VCID: 58E2E63A82EE562A17B-810C
Address 75: Telematics (J949) Labels:* None
Part No SW: 4K1 035 283 C HW: 4K1 035 283 B
Component: ConBox H09 0233
Serial number: 005CCA12F120680 Dataset Number: 8W0909612C 0012
Coding: 01C020FE4040800000
ASAM Dataset: EV_ConBoxAU651 002004
ROD: EV_ConBoxAU651_002.rod
VCID: 280296FAF20E26AA67B-817C
1 Fault Found:
458759 - Control Module Incorrectly Coded
U1014 00 [008] - -
[ECU_coded_wrong]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 66
Mileage: 34923 km
Date: 2023.10.18
Time: 17:34:50
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 M HW: 4M1 713 041 G
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 19071953933586
ASAM Dataset: EV_GSMWaehlZFAU736 001017
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 3D2C57AE0D8C930224D-8168
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W0 907 217 E HW: 8W0 907 217 C
Component: BVS H18 0055
Dataset Number: 8W0909466F 0039
Coding: 0404090100000204022023A2AD0000FC10F0C020C000
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: 3E2E50A2008A881A3D7-816A
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8W0 907 159 H HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0008
Serial number: 190605201753
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 46DE3842585AD0DA757-8112
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 4M0 959 795 M HW: 4M0 959 795 J
Component: TSG HFS 010 0384
Serial number: 0000383781602 Dataset Number: 8W0909897H 0034
Coding: 000F0B200000108040000020
ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
VCID: 4AC60C724C4234BA91F-811E
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 010 0384
Serial number: 0000383781870 Dataset Number: 8W0909896H 0034
ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4K0 907 594 AB HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: 8W0909469E 0014
Coding: 228000049100
ASAM Dataset: EV_SunRoofCONTIAU736 009011
ROD: EV_SunRoofCONTIAU736_009_VW48.rod
VCID: 74BAB28A7E46124A1B3-8120
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 F HW: 4M0 907 590
Revision: --------
Coding: 0E8002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
VCID: 353C4F8E35BC4B42ECD-8160
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
Dataset Number: 8W0909471C 0008
ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
ROD: EV_LEDModLeftMELCOAU736_VW37.rod
VCID: 167EA802487AA05AC57-8142
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0003
Dataset Number: 8W0909472C 0008
ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----------(Elapsed Time: 03:37, VBatt start/end: 12.4V/12.3V)-----------
For good measure, I'll toss in the three screenshots the tech managed to capture during the session:
One note that may or may not be relevant: when going back in to clean up the retrofitted TPMS configuration, in the CAN Gateway (19), the option under Adaptation for activating Tire Pressure Monitor was no longer present. This was indeed present when I installed the system, and today I couldn't find it anywhere.
Any thoughts on where to start?
TIA
GG
