hi everyone. im trying to retrofit hill hold in a 2011 s5, so i bought an 1at abs module. it came from a 2015 s5, donor vin WAUGGAFR0FA008959. PN is 8K0 907 379 CP (ESP8 quattro H09 0020)
however, it seems i managed to get the only module that has 4 bytes coding i could find... hence not a lot of help found and the usual tutorial wont apply. if someone can help me with it id appreciate. even if by telling me its a no go so i can chase another module.
this is the coding that came with it: 281D1A01. from what ive searched, byte 0 indicates the vehicle, so for a5 should be 2D, and s5 should be 29. source: https://forums.ross-tech.com/index.php?threads/27749/
anyway... cant make the errors go away, and cant make the autohold button work.
THANKS!
00494 - ESP-Sensor Unit (G419); Incorrect Component
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 115
Mileage: 1050 km
Time Indication: 0
Date: 2009.07.09
Time: 01:10:46
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x0006
Hex Value: 0xBE97
Hex Value: 0x0001
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 115
Mileage: 1050 km
Time Indication: 0
Date: 2009.07.09
Time: 01:10:46
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x000C
Hex Value: 0xE397
Hex Value: 0x0001
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 115
Mileage: 1050 km
Time Indication: 0
Date: 2009.07.09
Time: 22:55:30
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x0015
Hex Value: 0x109C
Hex Value: 0x0001
01319 - Control Module for Distance Control (J428)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 115
Mileage: 1050 km
Time Indication: 0
Date: 2009.07.09
Time: 23:00:34
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x03A2
Hex Value: 0x0009
Hex Value: 0xB49C
Hex Value: 0x0001
