Results 1 to 17 of 17
    Dec 29 2015
    Nashville
    Thumbs up Weekend project (simplifying oil changes)
    20230319_130625.jpg20230401_170308.jpg20230401_170334.jpg20230402_174257.jpg20230402_174556.jpg
    I wanted a cleaner and faster way to do oil changes on the S4 so here is my solution.
    -5" round access panel bought from Amazon
    -6 stainless steel screws and nylon lock nuts
    -Fumoto valve with adapter in order to clear the oil pan recess. There are components that sit lower than the valve so I feel comfortable it won't get snapped off
    Cut a perfect hole in the splash shield under the oil drain plug with a hole saw and then drilled six holes for the screws and nuts. Insert the access cover and bolt on. Reattach splash shield. Now you don't have to drop the shield when draining the oil and no more mess with the fumoto valve
    Established Member Two Rings akop18's Avatar
    Aug 22 2021
    B8 Audi S4, B7 Audi A4 Cabriolet
    Dickinson, ND
    I like that idea, well done. Where did you find a cap like that?
    Sent from my SM-G988U using Audizine Forum mobile app
    Dec 29 2015
    Nashville
    I added some context to my post but amazon sells them for 10 bux
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Well done. Although I know it does not evacuate as much sentiment as pulling the plug, I have come to appreciate my Mityvac Fluid Evacuator. With topside access to the filter and me not having a lift, it makes oil changes much nicer.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Aug 05 2013
    N/A
    Clean idea, but I dunno about those valves. I’ve never trusted them. Everything else is 👍.
    Established Member Two Rings Spider96's Avatar
    Sep 30 2021
    Poughkeepsie
    I've used Fumoto valves on every vehicle I have owned in the last almost 20 years and never had a single issue. It's really a great little upgrade that makes oil changes easier, especially when you don't have access to a lift...
    Sent from my SM-G996U using Audizine Forum mobile app
    Dec 29 2015
    Nashville
    Quote Originally Posted by doughboy17 View Post
    I used to use an electric oil pump to suck out the oil but for some reason I can’t get all of it out. I stopped inserting the tube when it hits a hard stop and tried moving the tube all around. The last time I used this method I only extracted about 5.75 liters which makes me uneasy leaving that much used oil in the engine. When I filled up with oil it only took about 5.5 liters to get it to Max on my OEM dipstick.
    This is my first time using the Fumoto valve and I love the concept. Just hope it does not start leaking down the road at some point.
    Mar 31 2008
    eS-4
    CAL*SO
    I've always had a similar thought pondering about a hole in the plastic. Never thought about a cool lid like your!
    I'd def consider this and still just use the drain plug without the valve
    Dec 29 2015
    Nashville
    It's only about $15 in parts/hardware. You can just buy a hole saw and return it if you don't need it in the future. (Assuming you own a drill)
    Mar 31 2008
    eS-4
    CAL*SO
    link to the amazon? i might just do this lol..
    Senior Member Two Rings ccssid's Avatar
    Jul 03 2011
    michigan
    Quote Originally Posted by Fresh.S4 View Post
    https://www.amazon.com/Automotive-Au...-12&th=1&psc=1
    or
    https://www.amazon.com/Automotive-Au...-14&th=1&psc=1
    Sent from my moto g power using Tapatalk
    2011 S4 prestige. Imola 6mt.
    Senior Member Two Rings rockstar143's Avatar
    Oct 01 2013
    United States
    Cool idea but definitely fluid excavating is easier and gets pretty much all of it.
    Thanks for sharing!
    Junior Member One Ring
    Nov 25 2018
    MA
    Hate to be that guy buut.. does it whistle on the highway?
    Oct 01 2013
    United States
    LOL...a lady never tells! Next you'll ask her her weight!?
    Nov 25 2018
    MA
    Oh so a slight "humm"
    Actually kinda serious cause I might do it. Lol
    Oct 01 2013
    United States
    there's no way you'll hear that...
    if you do, turn up the barry manilow!
    Dec 29 2015
    Nashville
    Lol, nope no extra noise whatsoever. It only protrudes about 0.25" from the splash shield.
