Results 1 to 2 of 2
Thread: 2010 a4 2.0
    Jan 18 2023
    Ohio
    2010 a4 2.0
    Trying to figure out why it idles up and down when I'm sitting, loke at a light but if I put ut up in neutral it doesn't do it?
    Junior Member Two Rings
    Apr 14 2019
    Northeast, NJ
    Could be many many different things. I would catch up on all your maintenance items, make sure all the charge pipes are clamped down securely, and inspect vacuum hoses for leaks. If you have not replaced the PCV valve ever, that could be it. Lastly, getting a VCDS scanner will help you diagnose problems.
