Results 1 to 7 of 7
Thread: Emergency Oil
    Veteran Member Four Rings 09S5's Avatar
    Dec 04 2015
    A8L, 4X4, c6 VETTE, New CTS-V
    TN
    Emergency Oil
    I purchased 1 qt. Pennzoil Platinum full synthetic 5w-30. NO 5W-40 at all..
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by 09S5 View Post
    Question: Do I need an Fresh oil change ASAP since the oil is mixed? or could I get a few more miles out the current oil. I normally change oil between 3/4k miles.
    Since it's all synthetic, you should be fine for your planned 1-2K more miles before oil change. The slight difference in viscosity should not matter. You may be better served figuring out why your oil level was now unusually low.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Dec 04 2015
    TN
    Appreciate the knowledge.
    Sent from my SM-N976V using Tapatalk
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    You bought high end Pennzoil. Apparently they market two versions, one for US cars and one for "euro" cars. Probably the same oil but they list the different manufacturers' oil specifications. The "euro" version meets the appropriate VW spec. If you care, there are AZ threads where folk debate the relative merits of different brands of motor oil.
    Dec 04 2015
    TN
    Thank you for your help Sir.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Using the synthetic 5W30 is fine BUT it should meet the VW 502 spec. You are probably perfectly fine running it the last 2,000 miles but if you plan to change this weekend then that is fine as well.
    If you look at your owners manual it should state that 5W40, 5W30, or 0W40 are all acceptable but they need to meet the 502 spec.
    Dec 04 2015
    TN
    Valpo A7 I appreciate the help .
