Originally Posted by
joejoe3
Thanks Jake!
Quick questions:
1) does the tune rid the 4 cylinder eco mode?
2) if it has crackle, option to not have that?
3) in the videos, tcu shift point at 7200 but the clip show it shifting much earlier?
4) does the tune require adaptation?
5) does D mode still behave like stock, while all the fun resides in Sport?
No problem!
1) It does not, but if you want it removed, we can likely do that for you.
2) There isn't a crackle option yet. When there is, it will be optional.
3) The TCU is deciding optimal shift points. In manual mode you can rev it out.
4) You should have to do any manual adaptations, but after flashing it will start adapting right away.
5) While still enhanced, D mode is tamer than S.
Jake
