Results 1 to 4 of 4
    Apr 22 2020
    checking brake fluid
    Maybe a dumb question, but does anyone have any hints for checking brake fluid level without removing the battery/interior filter/ECU cover?
    Owner's manual says to just look, but the reservoir is sitting too low. And I can't see the fluid anyway, even if I pop the battery cover and stick a light in there..
    thanks
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Pull back the weather strip, grab the cover and pick it up. Do you have a good mechanic?
    Apr 22 2020
    Quote Originally Posted by CELison View Post
    Don't need a mechanic for this, just hoping to save a few minutes and wear/tear on the weather stripping.
    Thanks for the answer.
    Veteran Member Three Rings TwoSnelz's Avatar
    Sep 09 2016
    2001.5 Audi S4
    Northeast PA
    I have a point light i shine through the resevoir and i can see my fluid but I do have a less than 3000 mile resevoir on the car(its clean).
    Sent from my SM-G973U using Audizine Forum mobile app
