Results 1 to 2 of 2
    Junior Member One Ring EliteAudiNW's Avatar
    Apr 08 2019
    B6 s4 MT parts car
    Newport, wa
    Dead clutch pedal
    How do you bleed your clutch pedal
    Senior Member Three Rings All_Black_A4's Avatar
    May 20 2017
    2x B7 S4 Avants.
    Calgary, AB
    Quote Originally Posted by EliteAudiNW View Post
    I’ve always had best results using a vacuum bleeder. Process is similar to bleeding brakes. Attach the hose to the bleed nipple on the side of the slave cylinder and open the valve. Draw a vacuum, don’t let the reservoir run dry and watch the fluid in the hose til there’s no more air in the lines….assuming that’s your problem though. Close the bleed nipple then test your pedal. If that doesn’t fix it then you’ve got an issue somewhere else in the system.
    2007 Audi S4 Avant 6MT: JHM Intake manifold and spacers, JHM Long tube headers and FI exhaust, JHM light weight flywheel, JHM light weight crank pulley, JHM Short Shift trio, 034 motorsport engine mounts and Trans mount, Apikol snub mount, Apikol rear diff mount, H&R lowering springs, Hotchkiss rear sway bar, RS4 grille and Maxton carbon fiber side skirts, Full wrap W/Inozetek Midnight purple.
