Results 1 to 3 of 3
    Junior Member Two Rings Mar'd's Avatar
    Aug 08 2019
    S4 B7 Avant (2007), S5 B8.5 (2014)
    Northern New Mexico
    Throttle Body Not Calibrating-S4 B7
    New to the forum, not new to Audis. I did my due diligence searching the problem I'm having, not finding anything specific.
    My go-to shop confirmed the crazy idling and limp mode problem I was having was due to throttle body failure. I installed a new Bosch (077133062A) throttle body, and did a manual reset, once with the battery connected which got me nowhere, once with it disconnected. That worked for about a week, then the P0121 code started getting thrown again, and limp mode followed. However the car is still running better than before I installed the new assembly.
    I then brought it to the shop, they did a VAGCOM reset, adding the new throttle body to the system. All was fine for about 3 days, now it's back to limp mode and the same code being thrown. I have to think that something in addition to the TB is failing. ECU? TB position sensor? Maybe only a shaman can help??
    It might be worth mentioning that this follows the timing chains, guides and tensioners service, along with a ton of extra parts that needed replacing. All done by the shop mentioned. I'll be returning to the shop for this problem, but wanted to see if anyone has any ideas on what's going on. Thanks in advance.
    Feb 27 2008
    2017 Q7 Prestige 2010 Audi S5 Cab 2015 A6 Prestige 2007 S4 Avant
    New Jersey
    Its the wiring to the throttle body - Replace the pins in the connector and you will be good. I went thru 3 throttles thinking that was the issue.
    https://static.nhtsa.gov/odi/tsbs/20...24818-9999.pdf
    Aug 08 2019
    Northern New Mexico
    Quote Originally Posted by A4Ferrari View Post
    Wire pins and connector were done (000979038E 1J0973713), and that seems to have worked, now it's on to a P0121 throttle position sensor code. I replaced the accelerator module for good measure to no avail. I guess there's still more wiring that can be replaced?? Car is currently in limp mode awaiting service. I'll let my mechanic play with for a while, lol. I considered another throttle body too.
