Results 1 to 31 of 31
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    GT2871r Eliminator full build partout
    I'm about to finally about to park the car and start tearing into the engine now that all the other stuff is sold. If you're interested in any of the parts still available let me know, and I can have them ready to ship in about 2 weeks.
    There were many parts I decided to keep for the next build, but most of the big stuff is going to go. Keeping a couple small things like the AEB head, engine & chassis mounts, APR DV, IE timing tensioner, ecs boost gauge, carbon interior, ARP head bolts, S4 cluster, etc. And the rods are staying in the bottom end for whoever buys the car stock. Not worth the amount of effort to pull some $500 rods.
    The prices next to the sold items are the selling price, since everyone's always curious.
    SOLD Rotiform SPF 19x10 + Hankook Ventus V12 evo2 275/30
    $900
    SOLD BC Racing BR Coilovers
    $500
    SOLD USP Complete Bumper + Grille set
    $400
    SOLD 8V S3 Flat Bottom Steering Wheel + Euro S1 single stage airbag + B8.5 buttons + B7 Clock spring & Steering module
    $600
    SOLD MK1 RNS-E out of a B7
    $180
    SOLD Auto Dimming Rear View Mirror w/ Compass retrofit
    $50
    SOLD Ported OEM Exhaust Manifold
    $90
    SOLD turbo brace + all oil and coolant lines (ptfe lined stainless steel braided Summit hose)
    $150
    SOLD Magnaflow Touring Exhaust 16601 Catback
    $400
    Blown ATP Eliminator GT2871r
    30-40k miles on it between me and the previous owner. CHRA damage. housings could be salvaged.
    $200
    SOLD
    IE Drop In Rods with about 20k miles on them, for 19mm wrist pins.
    $300
    034 silicone turbo inlet pipe for 2.5" inlet
    $80
    034 Highflow Cat - 25k miles on it
    $250
    S4 Door blades
    $200
    Mishimoto oil cooler + 10AN lines, also PTFE lined SS braided hose + 034 thermostatic Sandwich Oil Filter Adapter
    $200
    Bosch 550cc Injectors
    $150
    Evolution Racewerks Sport FMIC
    $400
    Gutted Airbox with VR6 MAF & reusable K&N Filter
    $90
    Honeycomb Grille
    $25
    TheRetrofitSource Retro-Quik Kit with Morimoto projectors and ballasts
    $250
    034 Snub Mount
    $75
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Established Member Two Rings Jaywalker's Avatar
    Feb 09 2019
    Iowa
    Nice stuff! Flywheel situation?
    G.I.A.C. Stage II, AFE induction, 034 Diverter, ER FMIC, 034HFC, 2.0T coils, Miltek non res exhaust, 380cc injectors, 034 snub/bracket/motor mounts, Sparco 18's, lowered on Vogtland sport springs, S4 rear brakes/S8 Brembo 345mm fronts, Podi boost gauge,
    Neuspeed solid shifter, S4 lip spoiler/door blades, honeycomb grill, tinted side markers, black Helix E-code headlights.
    Mar 25 2015
    Placer County
    Quote Originally Posted by Jaywalker View Post
    Keeping all the nice drivetrain stuff for the next build, and leaving the bottom end etc for the buyer of the stock car. Building a full frame 2.0L avant next. already sold the valvetrain too since i’m going oversize with IE race cams next.
    only gonna pull the parts from the head and up. Only stuff worth your time considering your current build would be the turbo and injectors (assuming you’re running pump gas, 550’s nowhere near enough for ethanol)
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Veteran Member Three Rings 1.8Turbo4me!'s Avatar
    Jun 10 2009
    S.F, CA --> Houston, TX
    damn, want a few but timing is off.
    Mar 25 2015
    Placer County
    Adding my old headlight setup.
    -Morimoto Mini H1 projectors, already mounted to reflectors via laser-cut fiberglass adapter plates, ready to drop into your halogen housings. With cutoff solenoid ready to be spliced in as optional double-highbeams
    -Morimoto XB35 ballasts w/ igniters
    -5k bulbs
    -adapter harness to plug into your H7 plugs
    $250
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Mar 25 2015
    Placer County
    Selling the RNS-E as I have too many of these already.
    Excellent condition, no broken or faded buttons, everything working. map dvd included. Code included.
    $180 shipped
    SOLD
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Mar 25 2015
    Placer County
    034 Snub Mount
    $75
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Established Member Two Rings Rikah's Avatar
    Jun 04 2009
    C7.5 S6
    Las Vegas
    Quote Originally Posted by Gunnarrrrr View Post
    $180 shipped
    Still available?
    Sent from my SM-N986U using Audizine Forum mobile app
    Junior Member Two Rings
    Apr 17 2023
    Post Falls, ID
    Whats the power potential on the eliminator?
    Mar 25 2015
    Placer County
    Quote Originally Posted by Dmill1369 View Post
    low 300’s at the wheels on pump gas. I maxed out around there at 26psi.
    could probably get pretty close to 400 on ethanol but you’d need 1000 cc’s and a bigger pump.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Mar 25 2015
    Placer County
    ported&polished manifold on the left
    SOLD
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Veteran Member Four Rings Stock B6's Avatar
    May 25 2018
    Noggy B5 S4
    Twin Cities
    Well at least there's a silver lining to the part-out. One of the nicest B6's in the game GLWS!
    Racecar: Nogaro B5 S4
    Daily: C5 Allroad 2.7TQM
    Past: 71R E85 B6
    Junior Member One Ring
    Jul 11 2018
    Pittsburgh, PA, USA
    Is the 034 HFC still available?
    Mar 25 2015
    Placer County
    Quote Originally Posted by Stock B6 View Post
    oh jeez thanks babe makin me blush
    Quote Originally Posted by peedle View Post
    The cat is all yours
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Mar 25 2015
    Placer County
    Pulled some more parts today. The GT2871r eliminator has seen better days. got a little bit of shaft play. Definitely needs new seals, as it leaks a bit of oil. If someone’s up for a rebuild, hmu with an offer. keep in mind they don’t make these housings anymore.
    If someone wants the line kit too, lmk. It’s all braided stainless steel PTFE lined hose. comes with the oil restrictor and all adapters and banjos. Plug and Play.
    Also got the 550 injectors ready to go, and the 034 HFC is in great condition.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Mar 25 2015
    Placer County
    ER sport intercooler removed. $400.
    $250 for the 034 Cat
    $80 for the turbo inlet
    $100 for the eliminator braided stainless ptfe hose kit with all fittings
    $100 for the 550 injectors
    $200 for the full oil cooler setup
    $300 for the stock AEB head
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Feb 23 2020
    Ca.
    turbo sold? i need an eliminator housing….
    Mar 25 2015
    Placer County
    Quote Originally Posted by Portlandareae28 View Post
    Not yet, I wanted to have ATP take a look at it first to assess the condition. If the chra can’t be saved i’ll hit you up about buying it for parts. You have a good chra for it to use already?
    Planning on heading over to ATP early next week.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Feb 23 2020
    Ca.
    i have a gtx2867r that i would like to make as smog friendly as possible long term
    Feb 23 2020
    Ca.
    didn’t mean to reply
    Nov 04 2019
    Fargo, ND
    Hard to tell from the picture is the car dolphin gray? Interested in the door blades.
    Mar 25 2015
    Placer County
    Quote Originally Posted by btleier View Post
    Yes, but not sure if it’s worth shipping them vs. finding a local set and spraying them yourself if needed
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Feb 12 2008
    Michigan
    what year? im after a driver door module wire harness, without broken wires;)
    Mar 25 2015
    Placer County
    Updated original post with everything that's still available.
    Added IE rods
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Aug 22 2023
    California
    Did you end up visiting atp about the turbo? I don’t mind if it’s blown I’m just interested in the housing.
    Apr 14 2019
    Aurora Colorado
    I want the turbo if you don’t mind pm me
    Established Member Two Rings Fiction1990's Avatar
    Sep 23 2021
    Las Vegas
    If you still have the turbo, what kind of damage to the chra?
    09 A4 B8 3.2 lowered on raceland coilovers, 20x8.5 shift spring
    Sold 04 A4 Avant Quattro 1.8T 6m/t, Bilstein coilovers, Magnaflow catback, Hotchkiss sway bars f/r, fmic, hfc, underdrive crank pulley, 18" BBS CH., K04, MTM stg 2, 415cc injectors.
    Mar 25 2015
    Placer County
    Quote Originally Posted by Fiction1990 View Post
    lol
    it was still making a whole 26psi like this, somehow..
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Sep 23 2021
    Las Vegas
    150 shipped?
    Jan 12 2020
    NA
    I have a gut feeling my head is warped. I have to drive her home tonight and find out for sure. Do you still have any of those big port heads laying around?
    Mar 25 2015
    Placer County
    Quote Originally Posted by Nirvana09 View Post
    I’ve got a couple, you can have the one I was running cause it’s the only one that i’ve confirmed doesn’t leak or anything. just pm me
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
