Results 1 to 15 of 15
    Mar 27 2023
    Minnesota
    Ethanol on stage 1 tune?
    Hello everyone, I’m planning to buy B8.5 S4, and was gonna do simply a stage 1 tune from either IE or 034, along with an intake and possibly heat exchanger. I have a gas station with e30, e10, and e45. Would I be able to run any of these with only these mods? Thank you
    Senior Member Four Rings
    Jun 08 2021
    PA
    034 has an e40 stage 1 but you have to change to their HPFP.
    Mar 27 2023
    Minnesota
    Would I be able to run e10 or e15 without a ethanol tune or HPFP?
    Mar 31 2008
    eS-4
    CAL*SO
    Quote Originally Posted by DaveRad View Post
    you could probably even get away with e20 on a stock pump.
    Sep 17 2005
    Fremont, California
    A lot of US fuel rated 91/93 has E10 in it anyways. This would be no issue.
    If you want to experience a true transformation, upgrading your HPFP and running our Stage 1 E40 tune will be the key.
    Let us know if you have any questions!
    https://www.034motorsport.com/b8-b8-...al-pulley.html
    https://www.034motorsport.com/034mot...ercharged.html
    -Sean@034
    Jun 08 2021
    PA
    Would I be able to run e10 or e15 without an ethanol tune or HPFP?
    The E15 around here is 88 octane in which case you would not want to use it.
    Aug 16 2020
    Q
    Stage 1 you could probably get away with E45(stock boost) without a fuel pump. I ran E40 on a dual-pulley setup at 6,000 feet of altitude on a stock pump, 0 issues.
    However, most people just cut a tank of 91/93 with about 4 gallons of E85. It's the Octane you really want, so if that E15 or whatever is 86 Octane, it's garbage.
    Jun 08 2021
    PA
    This works once but you have to have an ethanol gauge to do it every tank. Promlem is if you mix up e40 then you’re adding to the existing mixture making it end up over e40 and compounds from there. Unless you have a content analyzer it’s impossible to keep it e40.
    Mar 31 2008
    eS-4
    CAL*SO
    Quote Originally Posted by Nillious View Post
    realistically, once you know the mixture, you'll never need to use an analyzer. ive got one installed on my p3 and NEVER check it. i ALWAYS just add 1/2g more of pump gas to make E42 every time. (ex: 3g of e85 to 3.5g of 91)
    download an app to get the "ratio" and just ALWAYS stick to that ratio every....single.... time.
    what im curious about is how the OP gets 3 different ratings of ethanol like that at the pump. you'd have to pick one of them and stick with it every time because yea deviating from the ethanol % will compound if you start mixing differently.
    Dec 25 2019
    Howell, MI
    That’s not the case. You don’t NEED to have a content analyzer, but it’s HIGHLY RECOMMENDED. I’ve been mixing ethanol for years and know my mixes. The “E85 Mix” app on android and apple is a calculator and it ensures a perfect mix everytime. I never factor in the ethanol in the 93, as a little extra won’t hurt (I set the ethanol content in gas to 0, within the app). Mine ends up being about E45 from the fuel line, when I tested it.
    Dec 25 2019
    Howell, MI
    I also test my fuel stations ethanol content every single time (there’s one gas station I do it every other time because I know they’re pretty trust worthy). You can plug in the ethanol content of the E in the app as well. It calculates everything for you. When you enter the tank percentage in the app, there’s a slider for the exact percentage you have. Say your needle on the dash shows 50% I would put it in the app is 53 to 55% because the needle is never super accurate. This is so you get some leeway. You will never come up short, when the tank is full and you’re like oh shit I didn’t get the required ethanol gallons in.
    Mar 31 2008
    eS-4
    CAL*SO
    Quote Originally Posted by Corydms7 View Post
    yup. you only need to check an app initially to get the ratio.
    Dec 25 2019
    Howell, MI
    It’s nice for maintaining it to. If my needle says 30% and I put in 33% into the app it’ll tell me the exact gallons of each. Takes the estimating of how many gallons you need out of it to.
    Quote Originally Posted by Fresh.S4 View Post
    Nov 02 2021
    Earth
    Longtime lurker here, but wanted to give my .02.
    I ran E85 to E90 on my stock pulley (stage 1 - custom tuned by me) 2011 B8 for about 16K miles with the stock HPFP without a single issue. I'm now dual pulley + w/m + E40 (also custom tuned by me)
    My buddy has run the same tune on his 2010 for about 5k miles also on the stock HPFP. In my opinion you should be fine running with any OTS stage 1 ethanol file on the stock HPFP.
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    Quote Originally Posted by shawkur16v View Post
    Logs?
