Currently finishing the install of a PT6062 STK but wanted to start sorting out the details of the next engine build. Got my hands on a used BEL engine recently. I’m making a list of parts to collect and I’m hoping for some forum assistance with filling in the blanks, add missing items and/or recommendations on how to achieve my goals in a different way. I’m under no illusion this will be cheap but don’t want to spend more than what’s necessary. Target is north of 650whp on 93 pump gas with an 8,000rpm redline. From what I’ve read, this is a bit of a tall order without E85 but I want to try. Below is a list of what I’ve created so far. Thanks in advance to those who decide to chime in.
Block:
- Stock Crank (Have)
- Rods – Integrated Engineering
- Rod Bearings -
- Pistons/Rings -
- ARP Hardware
- 034 Billet Aluminum Rear Main Seal Kit
- FluidDampr Crank Pulley
- Balancing
- 034 Compression Lowering Head Gasket
Heads (8000rpm):
- 2.7 Heads (Porting = 2.8 sized)
- 2.8 Intake Cams
- Supertech Valvetrain Upgrade Kit +1mm Intake / +1mm Exhaust
- ARP Hardware
- "Monster" Intake Manifold 2.7 Ports (Have)
- 034 Phenolic Spacers - Transition 2.7 to 2.8 Port Size
- RS4 Throttle Body (Have)
Turbo Kit: (Have)
- 034 STK w/ 2.8 Exhaust Manifolds
- PT 6062 .64AR Hot Side
- PB5 FMIC Kit 2.5" Inlet 3.0" Outlet (600hp+ Core)
Fuel (93 Octane)
- Stock Lines/Rails
- Walbro 450LPH Fuel Pump (Have)
- 1000cc Bosch EV14 Injectors (Have)
Clutch/Flywheel
- Ringer Racing Stage 4 Kit (840FtLbs @ Flywheel)
Planning to take the block in for cleaning/honing services. Compression lowering head gasket should assist with pump gas. Since I have 2.7 heads I'm of the mindset I should have them ported but the cost of porting vs buying 2.8 heads is something I haven't researched yet. I've heard mixed reviews of even going with the Torque Factory BC Valve Springs and Titanium Retainer kit over the Supertech kit for 8000rpm. Still learning more about that. I had a water/meth bung welded into my charge piping. If this is highly recommended then I'll plan to add an AEM kit to this list. The clutch kit is more than what I'll need but I like the wiggle room should I be able to increase power over time.
