Results 1 to 8 of 8
    May 07 2022
    Saint George, Utah USA
    Anyone Have success with a Peddle Throttle Controller
    I own a 2022 Audi RS6 and experience Pedal lag when leaving a green light. Due to most new cars with Drive-by-Wire, there is a slight lag when pushing down on the Pedal./Throttle I have used a Plug and Play Throttle controller on my American car, but was curious if anyone has had any success with using a Pedal
    /Throttle Controller on an Audi RS6. I'm obviously trying to avoid an expensive ECU Tune and voiding any warranty.Thank you for your feedback
    Marc
    St. George,Utah
    [email protected]
    Veteran Member Four Rings brad65ford's Avatar
    May 30 2005
    fl
    you ever purchase one?
    Dec 09 2019
    Charlotte, NC
    Quote Originally Posted by SaintRS6 View Post
    Marc
    St. George,Utah
    [email protected]
    I have had s Sprint Booster in my Audis. Easy install and programmable. SprintBoosterUSA.com
    Dec 09 2019
    Charlotte, NC
    It will wake the throttle up incredibly
    Veteran Member Four Rings 09S5's Avatar
    Dec 04 2015
    A8L, 4X4, c6 VETTE, New CTS-V
    TN
    Sprint Booster is the best.
    Plus you can set it up so that if you go into a store the car won't move until u put a 4 digit code in.
    https://youtu.be/Izp8i7Q9fs0?si=TwPOhdpCZy71qI0h
    Sent from my SM-N976V using Tapatalk
    Junior Member Two Rings
    Feb 05 2023
    West Texas
    yes pedal commander on my 2023 RS7. Love it
    May 30 2021
    Northeast
    I installed a DTE Peddle box on my 2022 RS7. It definitely improves throttle response off the line. It does not, nor did I expect it to, get rid of the inherent turbo lag in these engines. My previous car, an F90 M5 did not have the same kind of lag so it must but related to the induction path.
    2022 RS7
    May 30 2005
    fl
    Sadly I don’t believe it’s turbo lag. It’s software hindering performance, it’s all torque management. Thank you audi/VW/vag. Anyone who’s had a c7 rs6 or rs7 understanding audi put some strong nanny’s on these porkiers. Had a feeling pedal box stuff only helps after this condition. Appreciate you sharing this. Only way we are going to know is when ds1 is released. Tuners will be able to remove this for us.
    If anyone is wondering what I’m referring to. Try from a dead stop to pull out on the street and kick your big ass sideways. Delay delay delay of power. Doesn’t matter if you going straight since removing esp fully off work will on these unlike Mercedes you need to revise body modules. This condition makes the car (even though it’s not) feel slow.
