Results 1 to 4 of 4
    Dec 14 2021
    Lithuania
    Lowering spring help
    2010 B8 Avant, NOT sport package, so basic suspension. What lowering springs works with oem shocks? Will it be to much for basic shocks? What additional things I should consider?IMG-20211102-WA0096.jpg
    Sent from my Pixel 7 Pro using Audizine Forum mobile app
    Jul 16 2018
    Atlanta
    Hey, it's my car. :-) Except you get MMI 3G. :-P
    I'd expect to be getting dampers matched with whatever springs you intend to use. The stock 1BA dampers are expecting a home position that's much higher than what "lowering" springs are going to sit at. And they are not going to necessarily have the damping profile necessary for springs that are going to have much less viable travel distance. I'd expect to replace the springs, dampers, and bump stops as a set.
    Senior Member Three Rings A4B8 2.0tfsi's Avatar
    Nov 02 2017
    Sweden
    There's quite a few peeps that don't like sport or sline springs and shocks. You could try to arrange a swap, even if it would be a difficult one, if you don't get hold of one that already has them off.
    2012 A4 B8 Avant 6MT F23L Custom Tune 3" 200 cell DP Sachs Performance Clutch
    Veteran Member Four Rings rcprato's Avatar
    Jan 30 2018
    21 Jeep Grand Cherokee Overland
    Rochester, NY
    You look like you are in a dry no winter weather location so getting the pinch bolt out for upper control arms should be doable, mine were a nightmare when I replaced springs and shocks on my 09 Avant. Went with S-Line sport springs and Bilstein sport shock and really liked it.
    My son put Vogtland coilovers on his VW GTI, rode nice.
    https://www.urotuning.com/products/v...ant-all-968116
