Results 1 to 25 of 25
    Junior Member One Ring
    Apr 14 2017
    New England
    OEM 0A3 TDI 6th Gear
    Is anyone aware of the OEM Audi part number for this part?
    JHM used to stock them, but no longer. My recollection was that it was a 0.56 gear ratio available in a European TDI of this vintage that also ran the 0A3 TDI gearbox.
    Thanks in advance
    Jan 29 2017
    B7 RS4, B15 Sentra Spec V
    San Antonio, TX
    May 20 2010
    As that thread is about an 01E, does this apply to an 0A3?
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Jan 29 2017
    San Antonio, TX
    Need the get the 0A3 gearing but all the 6th gear info is the same for the TDI IIRC, there is info in this section of the forum but I have that one for easier finding.
    May 20 2010
    Gotcha. Thanks!
    Apr 14 2017
    New England
    Quote Originally Posted by CrickiKaze View Post
    Thanks for that thread. My understanding from reading it and others was that these are different gearboxes and thus the TDI 6th gear would be gearbox-specific.
    Are you saying that the TDI 6th gear can be used in both the 01E and 0A3? I'm a little confused.
    I should also mention that I already reached out to Scotty at Advanced Automotion to ask if he has any TDI 6th gears for the 0A3, and he noted that he has them for the 01E only.
    When I reached out to JHM (who previously stocked the imported TDI 6th gear for the 0A3), they unfortunately have no record of the part number.
    Jan 29 2017
    San Antonio, TX
    Then I must be mistaken, thought the 6th gear ratio transferred over regardless of the tranny as the shafts was the same size.
    Haven't looked into it for a long time and when I found it again I just wanted the ratio and teeth numbers as when I last was looking years ago all was discontinued.
    There is a thread in the how-to section IIRC.
    Jan 29 2017
    San Antonio, TX
    Here is the DIY, thought it had the part numbers but it was a JHM kit.
    https://www.audizine.com/forum/showt...on-Disassembly
    Apr 14 2017
    New England
    Awesome thanks
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    Probably won't help, but I bought my .53 6th gear from Scotty (80 mph=2200revs vs 3200 with stock .78 6th). That was 12 years ago. Helps a lot with 93 octane.
    Old Geezer, formerly known as Stud Muffin
    Apr 14 2017
    New England
    Quote Originally Posted by QIKRNU View Post
    @QIKRNU
    Very cool, thanks. Definitely helpful. What rough mpg figures did you get on the highway, and was it in an S4 or RS4?
    Do you know if the 0.53 6th was from an 01E or an 0A3 transmission? It seems like per @CrickiKaze that it might not matter, but I'm trying to clarify before I pull the trigger on one. Scotty has 0.56 for the 01E in stock, but I don't want to buy it only to find that its incompatible with the 0A3 trans in my RS4.
    Thanks all
    Jan 23 2014
    '13 Touareg TDI - '08 RS4 Mug/Ti
    Derby City
    nash_TDI recently got one.. Maybe his in an OEM box with the p/n on it. Hit him up, he's an active member.
    Apr 14 2017
    New England
    Veteran Member Three Rings outsider6661's Avatar
    Jul 02 2007
    2008 RS4, 2016 S5 Black Optics
    Markham Ontario, Canada
    This is what I found.
    0.56 ratio 23/41 Teeth.
    01E311362D
    01E311160D
    Not sure who sells them anymore, I've been searching but haven't found anything
    This is where I came across the info
    https://www.pistonheads.com/gassing/...f=86&t=1200895
    Sent from my SM-N975W using Tapatalk
    Jun 18 2010
    East of Cincinnati
    Quote Originally Posted by Octavian View Post
    @QIKRNU
    Thanks all
    It's a 2004 S4 Avant. 25 mpg is possible on the highway, but only if you keep your foot out of it. OA3 gearbox. I don't think the 'boxes are the same.
    Jul 02 2007
    Thanks in advance
    Any luck sourcing the tdi sixth gear? Are these even available still ? Or is it just another NLA part?
    Oct 11 2007
    Suburbia
    And this can be done with an RS4 as well, right?
    12' R8 Daytona/CF V10 6MT
    07' RS4 Daytona/Panda
    Jul 02 2007
    Quote Originally Posted by WinterRunner View Post
    Correct. Just need find out where these are available for purchase. Jhm use to have it listing for the gear. The only other place that used to stock them was advanced automotion but their website has been down for quite some time. I believe they had two gear sets to choose from. .56 &.53
    Jan 23 2014
    Derby City
    Can, and is oh so worth it
    Oct 11 2007
    Suburbia
    but noone can hunt down the parts needed, right?
    Jan 29 2017
    San Antonio, TX
    Tearing down a good tranny is the only way to get the gears due to them being discontinued, unless you find a set that someone has laying around.
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by outsider6661 View Post
    I know some people that can get the gears. One of the gears is NLA thru Audi. They are not cheap though because the main shops have stopped selling them. Pretty sure that they gears cost me $750.
    Yes because they are both 0A3 cases. I have installed them on RS4s but the RS4s lack the low end torque to be enjoyable below 75-80 mph in my opinion.
    It is hard to find a whole transmission that can be shipped to the USA. Along with most people don't have the special tools required to do the work.
    Jan 29 2017
    San Antonio, TX
    Quote Originally Posted by JimmyBones View Post
    What I was getting at with out saying it, difficulty is up there with cost, right there with you.
    Jan 23 2014
    Derby City
    Just an FYI, this is the RPMs before and after.
    20180706_124657 by Ron Wroblewski, on Flickr
    20191125_074631 by Ron Wroblewski, on Flickr
    I can tell you on this drive, I could not make it (342 miles) driving at a steady 8ish MPH over whatever posted limit is there... And then after the gear install, that same drive, under same conditions and inputs results in me making the entire drive and then still having enough gas leftover for a day or two of additional driving around town at either destination. Well worth it.
    https://goo.gl/maps/qP6CSN9QypLyvi1z5
    It's been a while since I've taken the RS4 on a substantial drive, but I think I last calculated a full tank around 25.5mpg over a mostly highway trip, which is noticeable increase from my SLC to Vancouver BC trip which I recorded (manually, not onboard computer) 20.8mpg.
    Jul 02 2007
    Quote Originally Posted by 87vr6 View Post
    What a big difference that gear makes. That's the.56 gear?
