Originally Posted by
rlme36
i haven't put eyes on this yet, but is there a way to add a fire sleeve to the existing hose that passes under the turbo by just sliding it on and chasing it down to provide protection?
I think you'd have a hard time getting your hands in there. The other end that connects to the turbo inlet is accessible, but its a very bendy line, I have doubts you'd be able to thread on a sleeve and getting your hands in there to Velcro on a wrap-able sleeve (like the one I used) would also be hard.
Jrbball7
The pcv breather hose is the one that usually goes bad right?
Either hose can go bad, cheap/easy fix is the front one, if the bottom one melts that's the $$$ fix unless you DIY. Another challenge with that bottom pcv hose is that it's meant to be one time use, per the manual there is no way to remove it without damaging it. I could not find a clever way to pull it off without just taking chunks out of it with pliers until it was willing to come off. Also the oil cooler is there and you don't want to smack/damage that. The reason I mention that, is because if you think you can snake your hand in there, you won't be able to pull it off anyway without clear access for pliers or similar tools.
If you want to do the easy one just for peace of mind it's pretty simple. The only trick is that officially it "can not" be removed from the inlet. You're supposed to swap out the inlet which comes with a new hose. Swapping the inlet is a lot more work than swapping the hose. In practice I think this is just lip service because of emissions regulation. What I found is that if you unhook the side off the PCV block first and then flip the whole line over towards the passenger side, in that position you can take it off quite easily without much force. Seems to be due to it's shape. I tried doing it the way others say to do it ("just pull hard") and it seemed like an absurd amount of force, but the flip trick made it super easy. Whether or not you'll find a source for just the PCV line without the inlet itself is another question. ECS claimed to have it, but the date kept slipping and then i found it was cheaper to buy it with the inlet anyway, not to mention faster.
I'll have a video on swapping those out soon.
