Hoping to get some help from someone with similar configuration. I have a 2015 A6 Quattro Premium Plus which includes the 360 degrees cameras (surround) option. I got the dreaded "ACC and braking guard unavailable" error in the summer. Scanning it with OBDEleven brings the same code as I have seen in other threads:
8E Image Processing
System description: BV-SG
Software number: 4G0907107E
Software version: 0041
Hardware number: 4H0907107
Hardware version: H32
Serial number: 00500012300614768603640000
ODX name: EV_BC7
ODX version: 001001
Long coding: 04C198180111
Trouble codes:
C110702 - Video line for image processing Signal error
static
The camera itself seems to be responding without any codes:
85 On Board Camera
System description: DPC-SG
Software number: 4G0907217A
Software version: 0038
Hardware number: 4H0907217A
Hardware version: H27
Serial number: 26213002542100000000368370
ODX name: EV_OnBoardCamerDPC
ODX version: 001007
Long coding: 6A060000
Trouble codes:
No trouble codes found
Now, I want to test the cable continuity to rule out cable issues (best case scenario) but the problem is that I can't find where that camera cable goes. From documentation that I got, it seems that the video processing module should be located under the passenger seat. I got to that module and although there is one there, it is not where this camera is connected to. My car has a surround view so it has four additional cameras: two on the mirrors, one in front, and one in the back - so those four cameras indeed go to the unit that is under the passenger seat. Only those four cameras go there - there are four connectors on that unit. The ACC camera that is behind the rear view mirror cable does not go to that module under the passenger seat carpet. I signed up for erWin for a day to download all documentation, and even there it shows the module being under the passenger seat but it is not the same configuration that my A6 has. My only guess is that there is another module under the DRIVER seat maybe, that's where it may go... but it is a bitch to get under the carpet on the driver side, so I was hoping someone may confirm if they have 360 view as well, where that damn module is located. I am ready to pull my hair out... spent several days googling and searching... and came up with nothing concrete. Any help is appreciated.
Also, if someone has any tricks on how to lift the driver side carpet without taking half of the car apart, I am all ears. I removed the side trims, hood release, foot well trim, but the carpet is not lifting... it was much easier to lift it on the passenger side. Would love to find out if there is a way to get under there. Thank you.
