Address 53: Parking Brake Labels: 8K0-907-801-V2.clb
Control Module Part Number: 8K0 907 801 N HW: 8K0 907 801 J
Component and/or Version: EPB-4 H02 0005
Software Coding:
Work Shop Code:
ASAM Dataset: EV_ParkiBrake 001028 (AU48)
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2D21534CDEDA8A017-806E
8 Faults Found:
68608 - Control Module Right Channel Voltage Supply
C1013 14 [137] - Open or Short to GND
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 141
Voltage terminal 30: 12.5 V
Internal Fault ID: 15
Vehicle speed: 510 km/h
Network management state: Reset
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: OFF
RWU: not active
DSD: not active
HTR: active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: Emergency running mode
Status of parking brake button: Not operated
Status ParkingBrake left: Initialization
Status ParkingBrake right: Initialization
70400 - Left Parking Brake Motor
C100F 00 [008] - Movement Difficult
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 98
Mileage: 130048 km
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 30: 11.8 V
Internal Fault ID: 22
Vehicle speed: 0 km/h
Yellow warning lamp: On
RWU: not active
DSD: not active
HTR: active
ECD: not active
Auto Adjust: active
Internal Parking Brake state: No enabling
Status ParkingBrake left: is closed
Status ParkingBrake right: Open
70912 - Left Parking Brake Motor Voltage Supply
C100D 13 [008] - Electrical Malfunction
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 98
Mileage: 130048 km
Date: 2023.03.13
Time: 09:46:48
Voltage terminal 30: 12.2 V
Internal Fault ID: 26
Function light in parking brake button: On
Red operating lamp: On
RWU: not active
DSD: not active
HTR: active
ECD: not active
Status ParkingBrake left: applied
10554390 - Supply voltage
U1011 00 [008] - Voltage too Low
[FC_LOW_V_BATT]
10554487 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[FC_LOW_BATT_ACTUATION_INHIBIT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 177
Mileage: 150715 km
Date: 2022.05.18
Time: 08:01:42
Voltage terminal 30: 6.9 V
Internal Fault ID: 42
Network management state: normal
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Status ParkingBrake right: is closed
721408 - Terminal 30
U140A 00 [008] - Open Circuit
[FC_UNEXPECTED_POWER_DOWN]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 137
Voltage terminal 30: 0.0 V
Internal Fault ID: 61
RWU: not active
DSD: not active
HTR: not active
ECD: not active
464384 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 98
Mileage: 150714 km
Date: 2022.07.13
Time: 00:02:23
Voltage terminal 30: 11.3 V
Internal Fault ID: 188
RWU: not active
DSD: not active
HTR: active
ECD: not active
Internal Parking Brake state: static
Status ParkingBrake left: Open
467968 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FC_SIGNAL_TSG_FT_1_ALT_OUT_OF_DATE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 98
Mileage: 150714 km
Date: 2022.07.03
Time: 01:43:25
Voltage terminal 30: 11.6 V
Internal Fault ID: 208
RWU: not active
DSD: not active
HTR: not active
ECD: not active
