Results 1 to 18 of 18
Thread: Wheel Spacers
    Junior Member Two Rings
    Aug 30 2022
    Houston/Texas
    Wheel Spacers
    Hi everyone! I recently converted my B9 Rs5 to stud and nuts for my aftermarket wheels. I purchased the wheel spacers from 034 Motorsports only to discover that the hub-centric spacers wouldn’t fit the aftermarket wheels properly. Problem being that the beveled edge doesn’t allow for the spacer to seat properly with the wheel hub.
    I was considering to machine off the chamfer or the lip in its entirety. Any thoughts or other alternatives?
    Don
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Quote Originally Posted by dongram2676 View Post
    Don
    Spacers really require a precision fit to avoid vibration. I would not, in any way, try to alter a spacer like that. Any reason in particular you switched to studs? What wheels, and what is the width and offset?
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Aug 30 2022
    Houston/Texas
    Hi VVG,
    I switched to studs for ease of install and aesthetics. The wheels are Vossen HF7 20x10.5. Looking to add 10mm spacing.
    Aug 30 2022
    Houston/Texas
    +30
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Looking at the 034 website for these spacers, it states: "034Motorsport's 10mm Wheel Spacer Pair is designed to fit most Audi & Volkswagen vehicles with a 66.5mm center bore and 5x112mm wheel bolt patterns. These wheel spacers are manufactured from 6061 billet aluminum with a black anodized finish and feature a few cool features you will appreciate if you have had experience with spacers before. Wheel spacers increase track width to improve handling, allow for more brake clearance, and help achieve the more flush wheel/tire fitment you desire for your car. NOTE: Hubcentric rings will not work with these spacers. Also, wheels must have a 6.25mm chamfer (minimum) on the center bore in order for these spacers to fit properly. Please measure your wheels prior to ordering. Outside edge of bore chamfer must be 79mm minimum. See product photo of back of wheel for reference (under main product image)."
    Here's the product photo of the back of wheel for reference:
    Do your Vosseen wheels meet these specifications?
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Aug 30 2022
    Houston/Texas
    The bore dia matches, but the chamfer interferes. The spacers were purchased prior to wheels. So I was unable to verify the chamfer details on the wheel. Maybe Mops can recommend a spacer that will work with my setup.
    Sep 28 2010
    NW NC / DE
    Happy to help! What brand are the aftermarket wheels?
    Aug 30 2022
    Houston/Texas
    Vossen HF7
    Jul 18 2010
    NE Ohio
    Vossen HF7
    You're in excellent hands with Mops! Love that color and stance ...
    Aug 30 2022
    Houston/Texas
    Quote Originally Posted by LYKUNO View Post
    Thanks!!
    Sep 28 2010
    NW NC / DE
    Vossen HF7
    Send over your shipping address. We have a really nice US made 10mm spacer I run with my Neuspeeds and Rotiforms. I'm betting they'll work. I'll send you one to test fit and we can order you a set if it works.
    [email protected]
    May 21 2014
    United States
    [email protected]
    Mops, sorry to hijack, but I just purchased the RSE102’s from you. Should I be looking at spacers as well? Not looking to rub at all, but would prefer a flush look, if not just a bit inside.
    Mar 14 2008
    MA
    Quote Originally Posted by bbowers825 View Post
    My opinion....don't go too flush unless you are going to lower. Wheel/tire flushness and ride height have to be in the right combination to really look good.
    May 21 2014
    United States
    Quote Originally Posted by VVG View Post
    Couldn’t agree more, it’s gotta be low enough so if they poke it doesn’t look like a lifted jeep.
    Mar 14 2008
    MA
    EXACTLY !!! People just don't think about this. Gotta lower if you really flush it out. Or keep a little tucked if staying stock ride height.
    Sep 28 2010
    NW NC / DE
    Hey Bryan,
    You might could fit 10mm, 5mm for sure. But I would mount them with the 275/35 and see how they position. We can for sure get you spacers and lugs if needed.
    May 21 2014
    United States
    Hey Bryan,
    Thank you!
    Jun 29 2011
    FL
    Get the spacers from Supreme Power, they dont have the tapered base so they fit both OEM and aftermarket wheels.
    19' RS3 Uni Stg 3 ECU/TCU, IMS750 Hybrid Flex Tune (10.97@126mph On stage 1+ E85)
    21' RS5 Sportback Audi Exclusive Orange
    99' B5 A4 Quattro - Sold
