Results 1 to 8 of 8
    Junior Member Two Rings
    Dec 30 2007
    Atlanta, GA.
    RS5 V8 4.2 Intake Manifold Removal - Coolant Question (Oil Filter Housing Seals)
    Hello All,
    Tried search but did not get a return (post a link in case I overlooked it).
    I'm undertaking the oil filter housing removal job, and wondered how much coolant I need to drop from the system?
    Does anyone know?
    I will be removing upper intake housing.
    Please advise.
    UPDATE: All completed. Ended draining about a liter or so of coolant from the system. All worked well.
    Few images for the record:
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    Just a couple of quarts at the most since they are in the topmost portion of the system. Good time to remove the Coolant hoses going to the back of the intake inlets and the line going to the Coolant reservoir. JHM sells a kit but all you really need is 4 Silicone plugs. I think it's about a 5/8~3/4" on the Coolant reservoir and about 3/8" for the 3 plugs by the Oil filter housing. The Coolant 'T' next to the Oil filter housing needs a plug with a clamp, the other 2 don't have to have plugs but it keeps dirt/dust from getting in there. What's wrong with the oil filter housing? If you need a pic I've got an engine with the intake off on a stand.
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    A gallon of pink is all you'll need. That should mix 50/50 with water. Don't buy the pre-mix. (And you'll have leftovers for yearly top-offs)
    B6 S4, B8 A4, 8P A3, and something, something.
    Dec 30 2007
    Atlanta, GA.
    - - - Updated - - -
    Quote Originally Posted by hahnmgh63
    ... What's wrong with the oil filter housing? If you need a pic I've got an engine with the intake off on a stand.
    Thanks for that info. My RS5 is at about 150K miles and oil starts to seep out from the seal under the oil filter assambly. So, before I undertake the project I wanted to get more in-depth info. Feel free to post any images of thing I'm expected to remove.
    I've done a ton of work on my other Audi cars but this is a first time doing work to top of the RS.
    - - - Updated - - -
    Quote Originally Posted by RPMtech147 View Post
    will definitely be using oem pink coolant with distilled water mix.
    Jan 10 2008
    Roy, WA
    PM me your E-mail and I'll send you some pics.
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Jan 10 2008
    Roy, WA
    Gregg, did you get any of the pics I just sent you? I got a reply that said "User account is overquota" I sent 3 E-mails, the first 2 were around 11MB, the last one was probably around 4MB.
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Dec 30 2007
    Atlanta, GA.
    I did get two out of three email, and downloaded them. Feel free to send the third.
    Thanks You.
    Dec 30 2007
    Atlanta, GA.
    Thanks All who chimed in to help.
