Results 1 to 4 of 4
    Established Member Two Rings nhracecraft's Avatar
    Jul 07 2022
    2009 Volvo S60 2.5T AWD
    New Hampshire
    2010 Audi S5 4.2L V8 – Likely HPFP Issue Followed by VERY Alarming Number of DTCs
    I’ve encountered an alarming number of DTCs seemingly unrelated to the likely HPFP issue I’m attempting to diagnose with my 2010 Audi S5. I’ve posted the most recent Auto-Scan below, though I have several Auto-Scans I can post (if requested), and have detailed them below in order to give a good picture of what I’ve encountered. Here’s the Sequence of Events:
    12.28.22 – Car stalled while idling in a Drive-Thru lane. Restarted and drove normally afterwards. Auto-Scan performed indicated the following relevant Fault Code:
    008852 - Fuel Pressure Regulator Valve (N276)
    P2294 - 004 - Open Circuit - Intermittent
    I researched the N276 Issue here, as well as on multiple Audi forums and decided to wait until the cause was more conclusive. Though it seemed likely it could be the HPFP, it seemed it could also be related to few other things as well. Plus, it’s the middle of winter in NH, and I didn’t (still don’t) have a spare garage bay to chase an ‘intermittent’ issue while the care seemed to drive OK.
    3/10/23 – Got a Check Engine Light in the AM (Engine warmed-up at highway speed) followed by an EPC Light shortly thereafter. Auto-Scan performed a few hours after the vehicle returned home indicated the following Engine Fault Codes:
    008344 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 2
    P2098 - 002 - Too Lean - MIL ON
    000135 - Fuel Rail/System Pressure
    P0087 - 002 - Too Low - Intermittent
    P0087 - 008 - Too Low
    Curiously, the O2 Sensor Fault had a date three days prior on 3/7/22, though I’m told there was no MIL until that morning. My son drives this S5 and swears there was no MIL prior, even after multiple inquires to confirm it wasn’t unnoticed and/or possibly obscured by the steering wheel. The following Auto Trans Fault code was indicated as well:
    4765 - Functionality limited due to Engine Control Module
    P1719 00 [036] - -
    [Text noch nicht vorhanden - KFC_GBMOT-KFA_KSM]
    Intermittent - Not Confirmed - Tested Since Memory Clear
    I took the vehicle for a short/easy test drive to evaluate condition/drivability, and on the way back drove it a little more aggressively. Under moderate acceleration I observed an EPC Light as soon as the Engine exceeded 4000 RPM. As the vehicle had other pre-existing DTCs, I wanted to see which Faults re-occurred on the test drive. The post test drive Auto-Scan revealed a fault frequency increase on the following Faults:
    P1719 00 [036] - -
    I was fairly confident the Bank 2 HPFP was the issue due to the Lean condition indicated by O2 Sensor Fault, but wanted to do some further troubleshooting to confirm and rule out any other issue(s) as my research tells me that Low Pressure at the Fuel Rail can also be related to issues with the in tank Low Pressure Fuel Pump (Lift Pump?), Fuel Filter and/or potentially the Low Pressure Fuel Sensor. I did some monitoring with the Engine running using the Measuring Blocks function to look at Fuel Rail Pressure, as well as some other parameters and observed that the Fuel Rail Pressure was approx. 25 bar. Having watched the Ross-Tech video re: Fuel Rail Pressure Testing w/ VCDS, I decided to check for a Fuel Rail pressure increase after the Engine was shut off as the Coolant/Engine temp was appropriate, however I inadvertently shut the Engine off (and the ignition) without hitting the ‘Close Controller, Go Back Button’ which I only realized after VCDS lost communication with Engine Module! After realizing my mistake I restarted VCDS but I was unable glean anything meaningful/definitive from looking at Fuel Rail pressure with the Engine off. After looking at Measuring Blocks and Advanced Measuring Values for several minutes, I attempted to start the vehicle, but it did NOT want to run at all. I made 4-5 attempts to start it, but it was only stumbling/barely running, and seemed it would stall, so I’d shut it off.
    After letting the vehicle sit for 1 ½ hours or so, I decided to attempt to start it again. It started right up, though it ran a bit rough, however in addition to the MIL and EPC lights, I was immediately met with an alarming number of other faults indicated in rapid succession on the Instrument Panel (ESP Fault, Parking Brake Malfunction, TPMS Malfunction, ABS Warning Light) upon startup. I shut it down, planning to further investigate the following morning.
    3/11/23 - I was concerned about Battery Voltage potentially having an impact, so I checked voltage first thing prior to connecting to the vehicle with VCDS. Voltage measured 12.3V at the Battery, and 12.2 at the under hood terminals. I then performed an Auto-Scan and it indicated the following ELEVEN new Engine Fault Codes, which were set when I had started the vehicle the prior evening:
    005173 - Secondary Air Pump Relay (J299)
    P1435 - 002 - Short to Ground
    001112 - Evap System Purge Control Valve (N80)
    P0458 - 002 - Short to Ground
    004199 - Intake Air Switch-Over Valve (N335)
    P1067 - 002 - Short to Ground
    000256 - Mass Air Flow Sensor (G70)
    P0100 - 002 - Supply Voltage
    005715 - Please check DTC Memory of ABS Controller
    P1653 - 001 -
    P1653 - 008 -
    004763 - Fuel Pressure Regulator Valve; Bank 2 (N276)
    P129B - 004 - Open Circuit
    P0100 - 004 - Supply Voltage
    000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
    P0030 - 004 - Malfunction / Open Circuit
    000048 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
    P0050 - 004 - Malfunction / Open Circuit
    009217 - EVAP Leak Detection Pump Control Circuit
    P2401 - 002 - Short to GND
    There was also one new Engine Fault that was set when I attempted to start the vehicle previously, and it didn’t want to run:
    P2294 - 004 - Open Circuit - MIL ON
    In addition to the Engine Fault Codes there was the following new Auto Trans Fault code was indicated as well:
    2505 - Torque Management Feedback Signal A
    P2637 00 [039] - -
    The following new ABS Brakes Fault codes were also indicated:
    01314 - Engine Control Module
    013 - Check DTC Memory
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    As well as the following Parking Brake Fault Code:
    013 - Check DTC Memory - MIL ON
    In reviewing the Freeze Frame data, all of the ‘New’ Faults occurred with a Battery Voltage of less than 12 volts (basically collapsing from 11.7V to 11.2V before the Alternator picked up the voltage.
    3/12/23 - I do not have a Battery Charger suitable for an AGM Battery, so I connected a Booster Pack to the vehicle prior to doing anything further today. I then connected to the vehicle w/ VCDS, decided to clear all DTCs with the Ignition ON and then ran an Auto-Scan. I had hoped to clear any DTCs that were purely related to any low voltage condition that may have occurred. After the Auto-Scan I started the vehicle, and reconnected w/ VCDS. Many of the DTCs returned, and I ran another Auto-Scan to document the changes. While the Engine was running, I checked Fuel Rail Pressure and it was approx. 6 bar, while the specified pressure was 30 bar!
    At this point I’m pretty certain I need to replace both HPFPs, but due to all the other Faults that occurred, I’ve got a number of questions/concerns:
    - Did I somehow damage (fry?) the ECM when I shut the Engine off while using the Measuring Blocks application in VCDS? I ask because the instructions in Ross-Tech Fuel Rail Pressure Test video, specifically state “Exit out of the Engine Control Module, Click on Done-Go Back, then Close Controller-Go Back to exit out. When VCDS is No Longer Communicating w/ the vehicle, it is now ‘Safe’ to shut the Engine Off”. Is it NOT Safe to do otherwise, as I inadvertently did?
    - Were the add’l Faults likely caused by attempting to start the vehicle with low Battery Voltage, and could this have potentially caused any relay(s) or fuses to fail as a result, as many of those Faults still remain? Could that have also created a terminal condition for the HPFPs, both of which now have DTCs indicating they have failed Regulator Valves and a resultant significant drop in Fuel Rail Pressure?
    - What should I do here, and what should I do first as a next step? At this point I have not gone down the path of checking any relays or fuses (I’m not even 100% sure where I should be looking). I’m ready to move forward with purchasing new HPFPs ($1000 from FCP Euro) if that’s advisiable, but I’m not 100% sure what to do.
    What other issues do you think I’m dealing with here? Any help and/or guidance from the forum experts would be MUCH appreciated. Thank you.
    Due to limitations in the forum software, the final VCDS Auto-Scan is posted in the separate post.
    ETA - This is cross posted on the Ross-Tech forum as well
    If Some is Good, and More is Better.....then Too Much, is Just Enough !!
    Jul 07 2022
    New Hampshire
    Final VCDS Auto-Scan as follows:
    Code:
    Sunday,12,March,2023,12:45:47:41661
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
    Data version: 20221026 DS344.0
    www.Ross-Tech.com
    VIN: WAUCVAFR4AA039712   License Plate:
    Chassis Type: FR-AU48 (8T0)
    Scan: 01 02 03 05 06 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56
              5F 6C
    VIN: WAUCVAFR4AA039712   Mileage: 243220km-151129miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: Cannot be reached 1100
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: OK 0000
    Address 01: Engine (J623-CAUB)       Labels:. 079-907-560-CAU.clb
       Part No SW: 8T0 907 560 T    HW: 8T0 907 560
       Component: 4.2l V8/4V    H12 0002
       Revision: 76H12---
       Coding: 01140009190F0120
       Shop #: WSC 06192 000 00000
       VCID: 4BC36AD8E3CF3B834E0-801E
       VINID: 9D19539915A21114400C91C108AFB9F141
    11 Faults Found:
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:44:03
                 Freeze Frame:
                        RPM: 631 /min
                        Load: 32.9 %
                        Speed: 0.0 km/h
                        Temperature: 66.0°C
                        Temperature: 11.0°C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.859 V
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:44:03
                 Freeze Frame:
                        RPM: 631 /min
                        Load: 32.9 %
                        Speed: 0.0 km/h
                        Temperature: 66.0°C
                        Temperature: 11.0°C
                        Voltage: 14.859 V
                   P1653 - 001 -
                 Freeze Frame:
                        Fault Status: 01100001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:44:03
                 Freeze Frame:
                        RPM: 632 /min
                        Load: 34.5 %
                        Speed: 0.0 km/h
                        Temperature: 66.0°C
                        Temperature: 11.0°C
                        Voltage: 14.859 V
                   P1653 - 008 -
                 Freeze Frame:
                        Fault Status: 01101000
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:44:03
                 Freeze Frame:
                        RPM: 632 /min
                        Load: 34.5 %
                        Speed: 0.0 km/h
                        Temperature: 66.0°C
                        Temperature: 11.0°C
                        Voltage: 14.859 V
                 Freeze Frame:
                        Fault Status: 01100010
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:44:03
                 Freeze Frame:
                        RPM: 681 /min
                        Load: 34.9 %
                        Speed: 0.0 km/h
                        Temperature: 66.0°C
                        Temperature: 11.0°C
                        Voltage: 14.732 V
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:44:03
                 Freeze Frame:
                        RPM: 681 /min
                        Load: 34.9 %
                        Speed: 0.0 km/h
                        Temperature: 66.0°C
                        Temperature: 11.0°C
                        Voltage: 14.859 V
    001431 - Thermostat for Mapped Engine Cooling (F265)
                   P0597 - 004 - Open Circuit
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:44:03
                 Freeze Frame:
                        RPM: 681 /min
                        Load: 34.9 %
                        Speed: 0.0 km/h
                        Temperature: 66.0°C
                        Temperature: 11.0°C
                        Voltage: 14.859 V
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:44:03
                 Freeze Frame:
                        RPM: 681 /min
                        Load: 34.9 %
                        Speed: 0.0 km/h
                        Temperature: 66.0°C
                        Temperature: 11.0°C
                        Voltage: 14.859 V
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:44:03
                 Freeze Frame:
                        RPM: 700 /min
                        Load: 33.7 %
                        Speed: 0.0 km/h
                        Temperature: 66.0°C
                        Temperature: 11.0°C
                        Voltage: 14.859 V
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:44:05
                 Freeze Frame:
                        RPM: 686 /min
                        Load: 31.4 %
                        Speed: 0.0 km/h
                        Temperature: 66.0°C
                        Temperature: 11.0°C
                        Voltage: 14.605 V
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:44:13
                 Freeze Frame:
                        RPM: 628 /min
                        Load: 32.9 %
                        Speed: 0.0 km/h
                        Temperature: 66.0°C
                        Temperature: 12.0°C
                        Voltage: 14.732 V
    Readiness: 0110 1101
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8K0 927 158 H    HW: 0B6 927 156
       Component: 0B6 42 FSIUSA H05 0005
       Revision: --H05---    CVN: 1C147449
       Coding: 001012
       ASAM Dataset: EV_TCMAL651 A01006
       ROD: EV_TCMAL651.rod
       VCID: 3B233A18B3EF8B03FE0-806E
    1 Fault Found:
              P2637 00 [047] - -
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 243224 km
                        Date: 2023.03.12
                        Time: 12:42:44
                        Engine RPM: 646.00 /min
                        Transmission input speed: 553 /min
                        Transmission output speed: 0 /min
                        Engine torque: 24 Nm
                        ATF temperature: 16 °C
                        Accelerator pedal position: 0.0 %
                        Clutch status: 0
                        Unlearning counter according OBD: 40
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
       Component: ESP8 quattro  H04 0010
       Revision: --------    Serial number: --------------
       Coding: 120D18
       VCID: 7AADFF1CFCD5720BA56-802E
    2 Faults Found:
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 172
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:43:03
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x6702
                        Hex Value: 0x0026
                        Hex Value: 0x46B7
                        Hex Value: 0x00FF
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 172
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:43:03
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x6702
                        Hex Value: 0x0032
                        Hex Value: 0x02B7
                        Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
       Component: BCM2 1.1      H02 0326
       Revision: 00002001
       Coding: 090000
       Shop #: WSC 06325 000 00000
       VCID: 78A9E514C2D9601BD32-802C
       Subsystem 1 - Part No SW: 8T0 959 754 M    HW: 8T0 959 754 M
       Component: FBSAUDIB8 IDG  H37 0060
       Serial number: 0509000060613002
       Subsystem 2 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Component: J764 ELV MLB  H37 0042
       Serial number: 0209000088194003
    No fault code found.
    Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
       Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
       Component: MEM-BFS       H10 0074
       Revision: AA000000    Serial number: 00001010032260
       Coding: 00017025002C00000000
       VCID: 43D342F8CB9FF3C3B60-8016
    Address 08: Auto HVAC (J255)       Labels:. 8Tx-820-043-3Z.clb
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0171
       Revision: C1000000    Serial number: 01201120090721
       Coding: 48122000
       VCID: 00598DF49A0928DBEB2-8054
    Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000393123
       Coding: 260010150634AF010000000300003D3D4F1C538800010161000000
       Shop #: WSC 06192 123 12345
       VCID: 3C213904B6618C3BF7A-8068
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 111109  H14 0070
       Serial number: SWF09110110289
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Serial number: 10679990
       Coding: 02532C
       Subsystem 3 - Part No SW: 8K0 941 531 AN    HW: 8K0 941 531 AN
       Component: E1 - LDS  H08 0090
       Serial number: 00000000000411091611
       Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
       Component: HOMELINK  H01 0010
    Address 10: Park/Steer Assist
    Cannot be reached
    Address 15: Airbags (J234)       Labels:| 8K0-959-655.clb
       Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
       Component: AirbagVW-AU10 H39 0560
       Serial number: 003EGD058TTV
       Coding: 303333334330303030304A55304C38543053
       ASAM Dataset: EV_AirbaECUVWAUDI010 003010
       ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
       VCID: 42DD47FCD405FACBBD6-8016
       Seat occupied recognition:
       Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
       Component: BF-Gewichtss.  H01 0050
       Serial number: 5810000R0900004QCY
       Crash sensor for side airbag: driver side:
       Serial number: 6334MSME4C6313046
       Front Passenger's Side Airbag Crash Sensor:
       Serial number: 6344MSME4D23596CS
       Rear Side Airbag Crash Sensor (on driver's side):
       Serial number: 6352QSME6E422104A
       Passenger side rear thorax airbag crash sensor:
       Serial number: 6362QSME6242500C9
       Crash sensor for front airbag: driver side:
       Serial number: 63732SME02432506L
       Crash sensor for front airbag: front passenger side:
       Serial number: 63832SME1B431120N
    Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb
       Part No SW: 8K0 953 568 F    HW: 8K0 953 568 F
       Component: Lenks.Modul   H16 0014
       Revision: --------    Serial number: 90304IKG000DH
       Coding: 000036
       VCID: 3D273400AD7B8533C04-8068
       Component: E221 - MFL  H02 0003
    Address 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb
       Part No SW: 8T0 920 981 N    HW: 8T0 920 981 N
       Component: KOMBIINSTR.   H34 0255
       Revision: 00000000    Serial number: CI556MHC9
       Coding: 831701000300D705020000
       Shop #: WSC 06325 123 12345
       VCID: 47CB56E8FFA7DFE36A8-8012
    Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
       Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0105
       Revision: EB800053    Serial number: 5300E09B1100C4
       Coding: 00C303
       VCID: 52FD77BC04E56A4B0D6-8006
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H06 0170
       Serial number: 190993A7291009
    1 Fault Found:
    01327 - Control Module for Parking Aid (J446)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 172
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:43:35
                 Freeze Frame:
                        Bin. Bits:    11111
                        Voltage: 14.60 V
                        Count: 6
                        Bin. Bits:    10011
                        Time: 25.40 s
    Address 36: Seat Mem. Drvr (J136)       Labels:. 8T0-959-760.clb
       Component: MEM-FS        H10 0074
       Revision: AA000000    Serial number: 00001001370640
    Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
       Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
       Component: TSG FA        H07 1201
       Coding: 011C03224000120102
       VCID: 50F97DB40AE9185B3B2-8004
    Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0124015782
       Coding: 0106069A007A440402B0003200000000
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0050
       Serial number: 00000000000000192303
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J245EE20SKB13  H01 0220
       Serial number: 0123456789ABCDEFGHIJ
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOM.clb
       Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
       Component: DSP Prem      H10 0190
       Revision: 00010001    Serial number: 34882000499501
    Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
       Part No SW: 8T0 959 792 J    HW: 8T0 959 792 D
       Component: TSG BF        H07 1201
       Coding: 011C03224C00120102
       VCID: 4FFB7EC817D707A3228-801A
    Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.clb
       Part No SW: 8K0 907 801 H    HW: 8K0 907 801 H
       Component: EPB Audi B8   H09 0100
       Revision: 00000003    Serial number: 10000000376024
       Shop #: WSC 00000 000 00000
       VCID: 343111249E31447B3FA-8060
    1 Fault Found:
                 Freeze Frame:
                        Fault Status: 11101101
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 172
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:43:50
                 Freeze Frame:
                        Voltage: 14.90 V
                        Count: 58
                        Speed: 0.0 km/h
                        Hex Value: 0x0270
                        Hex Value: 0x0001
                        Hex Value: 0x0101
    Address 55: Headlight Range        Labels: 8K0-907-357.clb
       Part No: 8K5 907 357
       Component: Dynamische LWR  H01 0010
       Revision: 00000001    Serial number:
       Coding: 0000002
       Shop #: WSC 06324 000 00000
       VCID: 77ABE628C3C76F63DA8-8022
    Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
       Part No SW: 4F0 035 082 A    HW: 4F0 035 082
       Component: Radio U SIRIU H45 0021
       Revision: AB001007    Serial number: 335K$097539801
       Coding: 020000010000000001
       VCID: 1D67D4800DBBE533E04-8048
    Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
       Part No SW: 8T1 035 664 B    HW: 8T1 035 664 B
       Component: H-BN-NA       H45 0042
       Revision: --------    Serial number: 490K6097537568
       Coding: 010200020206E1EF01000F0E000000030000
       VCID: 372B26288F47AF631A8-8062
       Subsystem 1 - Part No: 8R0 060 884 F
       Component: NAR 2009/2010  5304
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356KP091125124
       Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000408602
       Subsystem 4 - Part No: 8R0 906 961 A
       Component: CD-Database  1293
    2 Faults Found:
    03157 - Functionality limited due to Communications Disruption
                000 - -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 172
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:34:54
                 Freeze Frame:
                        Bin. Bits: 00000100 00000000
                        Bin. Bits: 00000000 00000000
    03278 - Functionality Limited due to Missing Messages
                000 - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 172
                        Mileage: 243224 km
                        Time Indication: 0
                        Date: 2023.03.12
                        Time: 12:34:58
                 Freeze Frame:
                        Bin. Bits: 00001000 00000000
    Address 6C: Back-up Cam.        Labels: 8T0-907-441.clb
       Part No SW: 8T0 907 441 C    HW: 4L0 907 441 B
       Component: J772__Rearview      0040
       Revision: --H03---    Serial number: 525PA8-J9X91MP
       Coding: 1000008
       VCID: 382925148E59A01B132-806C
    End----------(Elapsed Time: 01:37, VBatt start/end: 14.8V/14.8V)-----------
    Active Member One Ring murfs3's Avatar
    Aug 07 2021
    2017 Audi Q7 Prestige - hers
    Nor. California
    @nhracecraft - any update on this? Did you get the issue solved? What was it?
    I am getting 08852 and 00135 and also p2293 and p2294 (from different OBD scanners).
    I have done some of the basic easy stuff:
    - cleaned MAF Sensor
    - cleaned CAM position Sensor
    Fearing I may be looking at 2 HPFP's as well, but not sure. It could just be a sensor on the FP's, maybe the fuel filter, maybe the battery (but that was replaced less than 2 years ago).
    My initial symptom was intermitant rough drive all of the sudden, then EPC light came on. Have cleared all the random misfire in cylinder X codes and they haven't returned. I did clean the CAM sensor and then the car immedietly ran like junk for about 30 seconds and then it self adjusted back to how it has been running with EPC light on.
    Just trying to figure this out.
    Jan 12 2025
    Summitville, IN
    I know this is a long while ago, but my 2010 4.2L just had almost exactly the same cascade failure the OP did down to the car was sitting in a drive thru and the codes almost perfectly matched up. Since there has been no reply for a fix from the OP, I just wanted to share what fixed my car.
    I replaced just the HPFP sensors on the front of the pumps, a small metal flake came out of the pass side Hpfp with the fuel. There was also a 15a fuse blown in the row of fuses hidden in the ecu box under the windshield washer fluid fill point. I did have to unhook the ecu wiring harness to get below it for the fuse, so obviously negative battery terminal off for this job.
    I just wanted to share my resolution for this issue since some shops will try to claim you need an ecu or other expensive parts that you don’t need. I will likely keep an eye on my pass side Hpfp and replace both preventatively this summer.
    My entire tool list for this job was my Lisle wiring harness pin kit, a t30 Torx socket, a 10mm & 13mm socket, 1/4 drive extension & ratchet, and a 32mm wrench(although you could get by with an adjustable or pliers.
