Originally Posted by
Turbo510
during acceleration, it will pull harder if the throttle is lifted slightly,
Ooh. I have had this exact symptom on my 2001 1.8T for the last...forever.
I documented in a thread just here:
https://www.audizine.com/forum/showt...s)-Clogged-cat
Pertinent quote from (*oh my gosh*) 12 years ago:
After holding at full throttle for a bit, letting OFF the gas will cause the car to *accelerate* noticeably. I feel like this is significant.
Getting the throttle held just right is super tricky. But when I get it, the car *moves*. It's incredibly difficult - I have to let off enough to get the timing back, but not *so* much that I lose all the boost.
Anyway, I changed a bunch of stuff. Some in an effort to fix this issue, but most of it because it needed to changed for another reason anyway.
- Installed a High Flow Labree Cat
- Installed 2.5" exhaust
- Installed another OEM K03s turbocharger
- Changed Primary wideband O2 sensor.
- Changed Fuel Pump
- Changed plugs and coils
- Changed Exhaust valves and lifters
- Changed Timing belt
- Changed head gasket
I feel like I tracked the problem to being timing related. Both the logs and the butt-dyno say that the "acceleration" I feel when letting off the gas pedal is the ECU adding timing. More accurately it is reducing the amount of 'timing pull' - and quite a noticeable amount of it.
I do know that the engine is at least a little bit down on compression, although I have not tested how much.
My final thought as to the root cause of my timing pull is aged knock sensors that have become oversensitive. This is a known failure mode in some types of knock sensors. It is very common on late 90's Subaru 2.5 4-cam engines, for example. I went so far as to purchase a new pair of OEM knock sensors. Twice! (I actually forgot I had them and bought them again). Regretfully, I *still* have not installed them to see if this will fix the issue. Perhaps this is the year. I'm sorry this post was not helpful. I hope you have better luck than I have so far.
