Been busy and haven't been on the forums much lately.
I used FK WSSX (wide series, stainless) spherical bearings, specifically the WSSX-12T. I had these same bushings in my tracked Jetta for over 60,000 miles and have had them in my A3 for about 30,000 miles. They are completely noise free, but will wear out eventually as all things do. They sharpen the steering and increase road feedback through the steering wheel. The RS3 bushings are a very good compromise. The OEM A3 bushings allow for a lot of toe change as you corner, making the steering very imprecise.
The bushings do articulate quite a bit from full droop to full compression of the suspension. I just can't image urethane lasting long in this application, whereas the front control arm - front bushing is a perfect application for urethane or even a delrin bushing. To be honest though the front bushing is pretty darn stiff from the factory.
Spherical Bearings:
https://www.fkrodends.com/products/s...series/wssx-t/
I have a pair of these on my workbench, just haven't had time to install them yet:
https://www.ecstuning.com/b-whitelin...UaAmxNEALw_wcB
