Last November I purchased new wheels and tires (Aodhan AFF7 19x9.5 +35 with Continental ExtremeContact DWS 06 PLUS 255\35 ZR19). Last Tuesday morning I received a low tire
pressure warning and found the right rear was down about 5 PSI. I carry a portable air pump so I gave it some air. Last Friday the same thing happened again, and I accepted the fact I had a slow leak.
I pulled the wheel off and took it to Mavis Discount Tire. The guy behind the counter takes a look at it, sees it's an aftermarket wheel, and as much as he’d like to help is very concerned
his shop would damage it. Apparently the rim bead is too wide (or tall, or something to that effect) and his shop doesn’t have the proper equipment. He recommends a specialty wheel and tire shop.
Has anyone else had a similar experience? My wheel and tire combo is nothing extreme, by any means. Is this normal and to be expected with aftermarket wheels,
or should your everyday major tire repair shop be able to handle them?
