Results 1 to 2 of 2
    Junior Member One Ring
    Aug 09 2022
    New York
    Sunroof Rattle/Creak
    Hello all,
    I was hoping you will be able to assist me with my sunroof noise. I use my sunroof as much as I possibly can as I enjoy having all my windows down. Therefore it gets used and potentially something may be worn out hence the noise.
    I am positive it is the sunroof as if I press up on it, while closed, the noise goes away. If I open/crack the sunroof, the noise goes away (or so small I cannot hear it). I typically only hear this noise rattle/creak below 40ish MPH because because of the difference in how the suspension reacts when travel slow vs fast.
    I read there is adjustment screws in the sunroof, but I am unsure how to get to them. Mostly how to pull off the "accordion" without breaking it. Also, I am unsure if adjustment is a good thing as the sunroof does not leak. I was thinking if I adjust it upwards (mimicking me push up on the sunroof) that this may resolve my issue. What parts fail on these sunroofs? I have tried my best to look at the sunroof and guides to see if I see any witness marks or something that stands out but it looks fine to me. What have you done to fix your rattle coming from the sunroof?
    Dec 29 2017
    Phoenix, AZ
    2010 Avant // 2015 Allroad
