Results 1 to 11 of 11
    Junior Member One Ring nis240sxt's Avatar
    Feb 21 2023
    2013 Audi Q5
    Texas
    4" Turbo Inlet Install
    I bought a used 4" CTS turbo inlet and it didn't come with any bolts or vacuum hoses/connectors. Can i reuse the 2x factory Torx ones? For the PCV, i know I have to use a new one. Anybody know what type of bolt (size, thread) to get for it or the other ones if needed? Also, what size vacuum tubing/connector should i purchase to reattach to the wastegate. I've looked at several different vendor's install instructions and they are quite different. Looking for people with experience to see if i can get the best method to install this piece of hardware. Thanks!
    Jun 29 2011
    FL
    Quote Originally Posted by nis240sxt View Post
    Reuse the factory torx for the inlet. You can download the install guide for a Unitronic inlet and I believe they list the size of the bolt needed for the PCV hose, but when I did mine I also got a longer one just in case.
    19' RS3 Uni Stg 3 ECU/TCU, IMS750 Hybrid Flex Tune (10.97@126mph On stage 1+ E85)
    21' RS5 Sportback Audi Exclusive Orange
    99' B5 A4 Quattro - Sold
    Sep 01 2012
    Edmonton
    From what I remember you need to buy the unitronic wastegate line. Supposedly oem is too short. I'm doing my inlet soon also just whating on the WG line to arrive.
    Sent from my SM-G970W using Audizine Forum mobile app
    2018 RS3 Panther Black
    Jan 07 2013
    Charlotte, NC
    Quote Originally Posted by WAF View Post
    yeah definitely the unitronic wastegate line - DO NOT buy the apr wastegate line, 100% will crack within a year
    @tuxedo.ttrs
    Feb 21 2023
    2013 Audi Q5
    Texas
    Thanks everyone. That Uni wastegate line is just a high temp silicone hose with a barbed connector which I can source on my own. What about the actual install itself? Those instructions are all over the place. Some say to remove coil packs, some don't. Looking for the simplest install without having to undo unnecessarily.
    Sent from my Pixel 6 using Audizine Forum mobile app
    Jun 11 2012
    2021 Audi SQ5 | 2019 Audi TTRS | 2004 Audi S4 (parted out) | 2000.5 Audi S4 (sold) | 2001 Audi A4 1.
    Corona, CA
    Unitronic 4” Inlet and Intake Install Post Facelift TTRS
    https://www.audizine.com/forum/showthread.php?t=884139
    Feb 21 2023
    2013 Audi Q5
    Texas
    Quote Originally Posted by mtwallace85 View Post
    Thank you, this will help a lot!!
    Jul 11 2021
    Midwest
    The only reason why you need the new wastegate line is because the short metal section of the oem line doesn't want to fit well over the larger turbo inlet. I ordered the Unitronic replacement line, but didn't use it to replace the entire length of wastegate line. Instead, I just cut the Unitronic line to size to replace just the metal section of of the oem line that goes over the turbo inlet, thereby being able leave the remainder of oem line in place. That is an easy way to do it.
    Feb 21 2023
    2013 Audi Q5
    Texas
    Quote Originally Posted by Hollingsworth View Post
    Thanks, will do!
    Jun 11 2012
    Corona, CA
    Thanks, will do!
    This is outlined in my install thread just so you know.
    Jun 29 2011
    FL
    Also, I think Uni says to loosen/remove the wastegate actuator to install the inlet, dont bother with that noise, it doesnt need to be.
