Im trying to keep this car long term, and will eventually switch to HPtuners, unless uni helps out when it comes to the file,
When you look at the scan i posted, you will see the camshaft adjuster fault, I just replaced a couple of those connectors, but FCP doesn't sell the pins, so i amazon-ed some and will verify if that is what caused that. I did get 5 of them replaced though. and it's kinda nice to have ones that are not 1. impossible to remove. & 2 won't break, I already have ordered more.
There are a couple of things that i think are worrisome, and would like yall experts to take a look,
I will also include all of my Mods here too:
APR coil packs(blue)
034 Downpipe
ECS catch can
Roc Euro CAI
buncha inserts
Unitronic stage 2, I own all the way to K04, which I regret
Per ilspazzaneve
I'll usually do a run like this at the beginning to get the ambient conditions and check to make sure everything is OK.
Group 10 - Field 0 Outside air temperature
Group 15 - Field 0 Vehicle speed
Group 25 - Field 0 Engine speed
Group 39 - Field 0 Ambient air pressure
Group 345 - Field 0 Air mass
Group 352 - Field 0 Intake manifold pressure
Group 538 - Field 0 Cat. temperature; bank 1
Group 544 - Field 0 TI_1_HOM[0] (this is cylinder 0 injection time)
Group 556 - Field 0 Intake air temperature
Group 566 - Field 0 Throttle valve angle (don't be surprised if it only opens 80 degrees, that is normal)
Here's a knock log with all cylinders (the individual cylinders show how much timing is being pulled per cylinder due to knock)
Group 216 - Field 0 IGA_AD_1_KNK[0]
Group 217 - Field 0 IGA_AD_1_KNK[1]
Group 218 - Field 0 IGA_AD_1_KNK[2]
Group 219 - Field 0 IGA_AD_1_KNK[3]
Group 220 - Field 0 IGA_AD_1_KNK[4]
Group 221 - Field 0 IGA_AD_1_KNK[5]
Group 222 - Field 0 Ignition angle; actual
Group 623 - Field 0 Charge air pressure specified value
Here's one which I use to gauge performance
Group 233 - Field 0 Lambda probes actual; bank1
Group 625 - Field 0 RFP_AV
What to log:
Usually, the best logs are long pulls in 3rd or 4th from a nice low RPM, say 2500 or lower, up to redline.
Some 1/4 mile logs are fun too, from a dig.
Start your log about 10 seconds before your running, at least, since you may find on a slow PC the log file starts a bit late.
What to log:
This is my first log
https://1drv.ms/x/s!AlVJcavj0Krwi3qu...fp5G3?e=fRjtMh
Here is my second log(knock):
https://1drv.ms/x/s!AlVJcavj0Krwi3wg...3WRrP?e=V5AJWe
& Here is my third, this one was kinda short(performance) :
https://1drv.ms/x/s!AlVJcavj0Krwi36B...W_m6h?e=nU3iKk
I also saved the presets for logs, which means i won't have to pick them every time, if you want to drop a recommendation for what i should log, i would appreciate that.
RandomLog from earlier today:
https://docs.google.com/spreadsheets...=0&single=true
This is at idle, is there something wrong with this? the knock sensors seem wonky
So ive heard that the CPM engines are good at preventing knock, with the extra injector. per what my valves look like, it seems like its never actuated. Is there a way VCDS, or my tuner(Uni)
Here's the scan:
Code:
Saturday,04,March,2023,16:13:50:52160 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 23.3.0.0 HEX-V2 CB: 0.4631.4 Data version: 20230228 DS346.1 www.Ross-Tech.com VIN: WA1LFAFP6FA124101 License Plate: Chassis Type: FP-AU48 (8R0) Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 52 53 56 5F 62 6C 6D 72 VIN: WA1LFAFP6FA124101 Mileage: 213890km-132905miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (DET-CPMB) Labels:. 06H-907-115-CDN.clb Part No SW: 8R1 907 115 L HW: 8K2 907 115 L Component: 2.0l R4/4V TF H09 0005 Revision: ECH09--- CVN: 1097F4A1 Coding: 6A2A0013242600062000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_ECM20TFS0118R1907115L 001006 ROD: EV_ECM20TFS0118R1907115L.rod VCID: 3E25360870FB09FA3DF-806A VINID: 9D105C5915A01964410840400481E805E2 3 Faults Found: 7210 - Cam Adjustment Actuator B; Cylinder 1 P11A3 00 [047] - Elec. Malf. or Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 5 Mileage: 213862 km Date: 2023.03.04 Time: 14:12:51 Engine RPM: 782.50 /min Normed load value: 11.0 % Vehicle speed: 0 km/h Coolant temperature: 98 °C Intake air temperature: 48 °C Ambient air pressure: 850 mbar Voltage terminal 30: 14.489 V Unlearning counter according OBD: 40 Engine status: COENG_RUNNING Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3 10203 - Random/Multiple Cylinder Misfire Detected P0300 00 [100] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 213874 km Date: 2023.03.04 Time: 14:34:45 Engine RPM: 3752.00 /min Normed load value: 81.6 % Vehicle speed: 81 km/h Coolant temperature: 103 °C Intake air temperature: 24 °C Ambient air pressure: 800 mbar Voltage terminal 30: 14.418 V Unlearning counter according OBD: 77 Engine status: COENG_RUNNING Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3 10593 - Cylinder 3 P0303 00 [100] - Misfire Detected Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 213874 km Date: 2023.03.04 Time: 14:34:45 Engine RPM: 3752.00 /min Normed load value: 81.6 % Vehicle speed: 81 km/h Coolant temperature: 103 °C Intake air temperature: 24 °C Ambient air pressure: 800 mbar Voltage terminal 30: 14.418 V Unlearning counter according OBD: 77 Engine status: COENG_RUNNING Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3 Readiness: 0110 0100 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb Part No SW: 8R0 927 158 AS HW: 0BK 927 156 AL Component: 0BK 20TFSIUSA H19 1003 Revision: --H19--- CVN: B0AE2672 Coding: 000001 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMAL551211 002022 ROD: EV_TCMAL551211_002_AU48.rod VCID: 0E45A6C800DBD97A8DF-805A No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb Part No SW: 8R0 907 379 AS HW: 8R0 907 379 AS Component: ESP8 quattro H09 0020 Revision: -------- Serial number: -------------- Coding: 151D1803 Shop #: WSC 06335 000 00000 VCID: 117FBDB41165C68290D-8044 1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 203 Mileage: 213829 km Time Indication: 0 Date: 2023.03.04 Time: 09:53:11 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x07A2 Hex Value: 0x0015 Hex Value: 0x1097 Hex Value: 0x0000 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP Component: BCM2 2.0 H15 0711 Revision: 00002001 Coding: 0D854040000000000000 Shop #: WSC 06335 000 00000 VCID: 084990D0623F874A473-805C Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E Component: J764 ELV MLB H40 0046 Serial number: 3215000050445005 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb Part No SW: 8K1 820 043 BB HW: 8K1 820 043 BB Component: KLIMA 3 ZONEN H04 0122 Revision: C1000000 Serial number: 01111120160286 Coding: 6481208000 Shop #: WSC 30608 001 1048576 VCID: 698FB55459755E42B8D-803C No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH Component: BCM1 1.0 H16 0103 Revision: 08016001 Serial number: 00001034177201 Coding: 260000918634AFE01700480300003D0DCF9CC608A2090221000008004000030100000034000000 Shop #: WSC 06335 123 12345 VCID: 78A9E01012DFF7CA373-802C Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB Component: WWS416 150224 H12 0050 Serial number: 90243014150217221716 Coding: 01D513 Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB Component: G397_RLFS H06 0004 Serial number: 20192343 Coding: 02005C Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS Component: E1 - LDS H03 0031 Serial number: 00000000001203150316 Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A Component: USHL4.2 H30 0030 Serial number: 00000000095Z01E4B046 Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H03 0003 Serial number: 80A88A97000000000001 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 8K0-959-655.clb Part No SW: 8K0 959 655 R HW: 8K0 959 655 R Component: AirbagVW-AU10 H51 0812 Serial number: 003NED13E7YQ Dataset Number: 8R0909602J 0001 Coding: 303635313832383132304A55304C38523053 Shop #: WSC 06335 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 003114 ROD: EV_AirbaECUVWAUDI010_003_AU48.rod VCID: 4CC16CC03647AB6AA3B-8018 Seat occupied recognition: Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A Component: BF-Gewichtss. H02 0040 Serial number: 5810000R150000K4P9 Crash sensor for side airbag: driver side: Serial number: 6334MSME4F1D035DR Front Passenger's Side Airbag Crash Sensor: Serial number: 6344MSME4E7E2805S Rear Side Airbag Crash Sensor (on driver's side): Serial number: 6352QSME1D4E297A. Passenger side rear thorax airbag crash sensor: Serial number: 6362QSME384E1946R Crash sensor for front airbag: driver side: Serial number: 63732SME2C581B601 Crash sensor for front airbag: front passenger side: Serial number: 63832SME32585476/ No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q Component: Lenks.Modul H03 0003 Revision: C0062331 Serial number: 90862OCI000W7 Coding: 000017 Shop #: WSC 06335 000 00000 VCID: 48C950D022BF474A873-801C Component: E221 - MFL H03 0004 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb Part No SW: 8R0 920 981 N HW: 8R0 920 981 N Component: KOMBIINSTR. H35 0567 Revision: 00100000 Serial number: 03629FH3G Coding: 83BF22000301C705020100 Shop #: WSC 06335 123 12345 VCID: 45D759E415AD5A227C5-8010 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8R0 907 468 P HW: 8R0 907 468 D Component: GW-BEM 5CAN-M H11 0060 Revision: 1Z120030 Serial number: 3041Z1531500E8 Coding: 80C303FF00 Shop #: WSC 06335 000 00000 VCID: 4CC16CC036C7AB6AA3B-8018 Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C Component: J367-BDMHella H07 8043 Serial number: 9644856003 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 8R0 959 760 D HW: 8R0 959 760 B Component: MEM-FS H07 0077 Revision: AA000000 Serial number: 00000138789385 Coding: 00581B00000000000000 Shop #: WSC 06335 000 00000 VCID: 42DD42F804836D1A597-8016 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb Part No SW: 8T0 907 566 B HW: 8T0 907 566 B Component: SWA Master H05 0071 Serial number: 0363312597 Dataset Number: 8R0909535F 0021 Coding: 010211 Shop #: WSC 06334 000 00000 ASAM Dataset: EV_LaneChangAssis 001020 ROD: EV_LaneChangAssis_AU21.rod VCID: 3FDB4B0C77F100F2369-806A Lane change assistance control module 2: Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B Component: SWA Slave H05 0071 Serial number: 0363237273 Coding: 010211 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8K0 959 793 R HW: 8K0 959 793 P Component: TSG FA H02 0510 Revision: Serial number: 0000140938323 Coding: 011D13205E00440004 Shop #: WSC 06335 000 00000 VCID: 4FFB7BCCC7D19072C69-801A No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb Part No SW: 8R0 909 144 P HW: 8R0 909 144 B Component: RCEPS H43 0510 Revision: 00001000 Serial number: 0007490729 Dataset Number: 8R0909852J 0022 Coding: 000000010000 Shop #: WSC 06334 123 12345 ASAM Dataset: EV_RCEPSAU48X 008018 ROD: EV_RCEPSAU48X_008.rod VCID: 45D759E4152D5A227C5-8010 1 Fault Found: 2306 - Function Restriction due to Start Voltage Interruption U1410 00 [008] - - [Funktionseinschränkung der Lenkung durch Spannungseinbruch bei hoher Geschwindigkeit] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 243 Mileage: 213886 km Date: 2023.03.04 Time: 14:47:50 Write only channel ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP Component: BCM2 2.0 H15 0711 Revision: 00002001 Serial number: 0363765070 Coding: 0126063A20FA709587B005320004004F Shop #: WSC 06334 123 12345 VCID: 084990D0623F874A473-805C Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719 Component: GTO BF H01 0080 Serial number: 00000000000000965348 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B Component: J245EE04SKB03 H03 0090 Serial number: 0123456789ABCDEFGHIJ Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B Component: J394EE04SKB03 H03 0090 Serial number: 0123456789ABCDEFGHIJ 2 Faults Found: 01502 - Bulb for Rear Fog; Left (L46) 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 203 Mileage: 213879 km Time Indication: 0 Date: 2023.03.04 Time: 14:40:22 01506 - Bulb for Rear Fog; Right (L47) 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 203 Mileage: 213879 km Time Indication: 0 Date: 2023.03.04 Time: 14:40:22 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8K0 959 792 R HW: 8K0 959 792 P Component: TSG BF H02 0510 Revision: Serial number: 0000140993851 Coding: 011D13205E00440004 Shop #: WSC 06335 000 00000 VCID: 4EC566C8C0DB997ACDF-801A No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb Part No SW: 8K0 907 801 N HW: 8K0 907 801 J Component: EPB-4 H02 0005 Revision: -------- Serial number: 00000001637438 ASAM Dataset: EV_ParkiBrake 001028 ROD: EV_ParkiBrake_AU48.rod VCID: 3A2D3A186CD325DA017-806E No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb Part No SW: 4G0 035 082 H HW: 4G0 035 082 Component: Radio U SIRIU H66 0138 Revision: AB001007 Serial number: 156C00F8240959 Coding: 020007020100000001 Shop #: WSC 06335 000 00000 VCID: 2517F964F5EDBA225C5-8070 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 8R1 035 746 K HW: 8R1 035 746 G Component: H-BNT-NA H42 1040 Revision: -------- Serial number: 523CZ0F7533067 Coding: 160200060005A1EF55028B5E00000403140000000000000000 Shop #: WSC 06335 000 00000 VCID: 3FDB4B0C777100F2369-806A Subsystem 1 - Part No: 8R0 060 884 CJ Component: NAR 2015 1102 Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A Component: DU7 High H42 0104 Serial number: A130C/0F3298974 Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C Component: E0380 Bedient H02 0030 Serial number: 00000002178140 Subsystem 4 - Part No: 8R0 060 961 G Component: CD-Database 5950 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 G HW: 8K0 959 795 D Component: TSG HL H01 0510 Revision: Serial number: 0000141395130 Coding: 010C13204000240004 Shop #: WSC 06335 000 00000 VCID: 46D55EE828AB513A75F-8012 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 8T0-907-441.clb Part No SW: 8R0 907 441 A HW: 4L0 907 441 B Component: J772__Rearview 0040 Revision: --H09--- Serial number: 525PA8-JA1A355 Coding: 1020010 Shop #: WSC 06335 000 00000 VCID: 343114204237D3AADBB-8060 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb Part No SW: 8R0 827 851 D HW: 8R0 827 851 D Component: J605 Master H56 0330 Revision: -------- Serial number: 8R0827851D VCID: 3D2731047D7D12E2245-8068 Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D Component: J756 Slave H56 0330 Serial number: 8R0827852D No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb Part No SW: 8K0 959 795 G HW: 8K0 959 795 D Component: TSG HR H01 0510 Revision: Serial number: 0000141394663 Coding: 010C13204000240004 Shop #: WSC 06335 000 00000 VCID: 46D55EE828AB513A75F-8012 No fault code found. End----------(Elapsed Time: 01:59, VBatt start/end: 13.5V/12.5V)-----------
