Results 1 to 8 of 8
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Potential Upgrades to C7 A6 ??
    Hey guys (and gals),
    I've got at sage 2, single pulley 2018 A6 comp. Would swamping to a 93 dual pulley - supplemented with gallon or two of e85 or race fuel likely get me me under 12.0....? Or am I chasing a ghost?
    It's currently a 2018 and by the end of next month will have a new interior and body will be 100%, including wheels and tires. Hence, it's a beauty
    I could sell for high 30s and swaps to an s6 or S7. But, I'm thinking since this car has been nearly perfect, I may go Stage 2, dual, with supplemental APR cooling. Cost would be roughly $1800. It's already got a custom TCU and I feel I'm likely into the low 12s in legit quarter. In fact, with winter rubber, i'm activating traction control shifting at 85-90mph. So, it's got some balls!
    Thoughts, comments much appreciated.
    Sep 16 2020
    West Michigan
    I think that CREC engines can run full e85 on single pulley. What ECU tune do you have?
    They also have issues with the supercharger clutch at dual pulley levels.
    You should be into the 11's right now.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    If you are buying the car to go fast, that isn't what it was designed for. The car itself can be made to run 11s. Do you actually want a faster car because you want to beat a number or is it that slow that you need a faster car? I'm loving my Stage 2 DP car. I don't have the room to unleash it. I am used to it, so it doesn't feel really fast, but it is apparent by when I do get aggressive with the go pedal because nobody is near me. Seriously, the only thing that has been near me making me feel like I wasn't moving out fast was a TrackHawk and that was most likely modified because I live 2 minutes away from a high performance Dodge shop. The guy was on drag radials.
    The way that I see it is I could buy an older S6, but I wouldn't be happy unless I changed the turbos and then I'd be worried about the suspension breaking OR I'd buy a newer A6 and change the turbo. IE is destroying records with the 3.0 Turbo. The odd thing is the 2020 A6 and S6 where I live are only separated by $5000. If you stepped to a 2019 A6 the price drops dramatically by $25k.
    How fast do you want to go, how much did you want to spend. How far apart did you want to take the engine. What S6 only features would you want.
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Thanks for the reply. I've got APR stage 2, single pulley (SC pulley) and a Berk TCU tune. I haven't taken this car to the drag strip. I understand 0-60 "new/un-tuned" should be about 5.0 second and 1/4 mi should be about 13.0 seconds. That said, with an extra 100 ponies and higher, more agressive shift points, if feels much, much quicker than stock and is willing to drop a couple gears and get up and go when kicked!!
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    All great questions. And, I am embarrassed to admit, I don't have good answers. The power my car has now is fantastic, for a big, quiet comfortable car without rattles or maintenance issues. i hit the highway one day a week and am able to safely use the power the car has then, and only then.
    When I pushed my old BMW 335 XI over 20PSI, I broke it. Hence, chasing power, comes with a cost (time and expense). This car, at stage 2/single pulley levels has been a dream in terms of up-keep. My wife's Q7 is stage 1 is going in for a new Water Pump next week at 80K plus miles. It hasn't had any other problems. We've done a bit more than basic maintenance (shorter OCI, earlier plugs, filters and SC belt and, of course, full brakes), but that's it. for a 5000lb luxury hauler, it's got some go, and has been super reliable for 6 years!!
    Perhaps I should take all of that into consideration, and stick with what I know and what I know works!
    Senior Member Two Rings ndirish1994's Avatar
    Dec 29 2014
    Portland, Maine
    Slightly different platform but after experiencing single and dual pulley in my old S4. I don't think the added risk of dual pulley is worth it. While dual pulley was definitely faster, especially in the mid range, I actually ran my fastest 1/4 mile on single pulley because heat soak was so prevalent on my dual pulley set up even with a larger heat exchanger.
    2017 S6 Prestige / Daytona Gray / Black Optics / DS1 Stage 1 / TGK Dumpbox
    Formerly:
    2013 S4 / Glacier White / DSG / APR Dual Pulley / APR CPS / CTS Intake / AWE Track / KW V1 / Rohana RFX11
    IG: Portland_S6
    Established Member Two Rings WhiteA7's Avatar
    Apr 25 2020
    2022 Audi E-tron
    Ft. Worth, TX
    Change title to C7.5. Next just so you know, APR hasn't updated tuning for this platform in years. Another company with more recent tech advances for this platform may be beneficial. Your Transmission tune is great but I think you're leaving something on the table going with APR.
    2016 A7 Prestige. IE CAI. IE Single pulley E85 ECU tune. IE TCU tune.
    Veteran Member Four Rings ANMS4's Avatar
    Dec 18 2012
    Framingham MA
    STG2 DP with E and all supporting mods, you'll need cooling you can cut a sub 3 0-60 and be deep into the 11's. I was in my 2014 A6 :).
    2014 S8*SMR Intakes*HMD Exhaust*DS1 tuned by SLEEPERTUNED*E50* MELEN TCU TUNE
    SOLD 2014 A6-IE STG2 DP+ TB E40 tune and Melen TCU Flash, RS7 Airbox, AWE Touring Catback+Resonated DP, Ported SC By Shane
