Results 1 to 6 of 6
    Feb 13 2014
    Cos Cob CT
    Rs3 virtual cockpit power gauge stuck.
    Hi Everyone,
    So I just picked up my new 2019 rs3 last week and the power gauge is stuck, and the torque gauge is stuck at 4 but still works when I accelerate any ideas of what could be the problem?
    Senior Member Two Rings BDidz's Avatar
    Sep 18 2014
    Duluth, MN
    My guess is that the car is on DS1 with a flex fuel sensor installed.
    Blüberry
    Senior Member Three Rings sleepy_rs3's Avatar
    Mar 29 2021
    New York, NY
    Quote Originally Posted by BDidz View Post
    Even more dangerous could be that it's on DS1 and the ethanol content was manually set to 64%...that would not be good if you're running fuel which isn't ~64% ethanol.
    If it has a sensor then the number should have changed when you filled up your tank. OP - is that the case?
    2019 Glacier White RS3 | Unitronic Stage 2 ECU & TCU | Unitronic Downpipe, Intercooler, & 4" Turbo Inlet | CTS 4" pipe to stock airbox | 034 intake heat shield | DSC Sport Controller | Tyrolsport Deadset Subframe Kit | 034 Street Density dogbone kit | Valentine 1 Gen 2 Radar Detector with JBV1 app
    Feb 13 2014
    Cos Cob CT
    Yes, that’s exactly what it was. I was able to bring the car into my shop and shipped off my ecu to unitronic to get re-flashed.
    Feb 13 2014
    Cos Cob CT
    No, the numbers never changed when I filled up. I’m hoping everything goes smoothly with the ecu and the car gets back up and running.
    Jun 11 2012
    2021 Audi SQ5 | 2019 Audi TTRS | 2004 Audi S4 (parted out) | 2000.5 Audi S4 (sold) | 2001 Audi A4 1.
    Corona, CA
    Sorry, OP, I thought I responded to you right after you posted this thread but I guess my response never went through. Glad you found out the problem and it does sounds like it was manually set to that percentage because they probably weren’t using a flex sensor or the DS1 was no longer plugged in and that was the last reading. Did I read that right, why are you shipping your ecu to Unitronic? That doesn’t make much sense to me when you can just flash the car remotely.
