Results 1 to 20 of 20
    Veteran Member Three Rings shreddykrueger's Avatar
    Feb 14 2016
    S4 Avant
    Cannot figure out P0087 Fuel Rail/System Pressure - Too Low
    So I have been dealing with code P0087 Fuel Rail/System Pressure - Too Low for awhile now and cannot seem to figure out why. Ive looked through the posts here and a lot lead to the auto tech piston in the hpfp being the issue. Today, we replaced the hpfp with the stock piston and the issue is still occurring. Recently, did the avantgg lpfp mod with a walbro 450...still having the issue.
    Is there anything else I should be looking at? Im not feeling any loss of performance or fuel cuts, but the CEL is getting really annoying and I would love to get rid of it, but at this point don't know where to go
    S4 Avant (6MT)
    RCP dual pulley | AWE touring | JHM catted/baffled DP's | AEM water/meth | Ringer Stage III | RSNAV | Vogtland Coilovers | many other tings
    Established Member Two Rings poloshirt's Avatar
    Apr 06 2022
    Oregon
    I would start thinking about the HP fuel rail pressure sensor underneath the SC - G247. Try to log fuel pressure with VCDS or OBD11 and compare with specified range in DTC description (see below).
    2013 Audi TTRS - Daytona Gray Pearl
    2014 Audi S6 - Ibis White - JHM Stage 2
    2013 Audi S4 - Phantom Black
    Feb 14 2016
    S4 Avant
    Good call, I am thinking that might be the culprit at this point as I threw code P119A (fuel pressure sensor) today, so looking to replace g247 this week. Any idea what the p/n is? I cannot seem find one for the 3.0
    S4 Avant (6MT)
    Sep 16 2020
    West Michigan
    I have read of a lot of people having issues with Autotech and 034 HPFP pistons lately.
    In several cases, users switched to the pre-assembled IE unit and it resolved their problems.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Feb 14 2016
    S4 Avant
    I replaced the autotech hpfp with a different stock hpfp
    S4 Avant (6MT)
    Apr 06 2022
    Oregon
    Quote Originally Posted by shreddykrueger View Post
    03C906051C. FCP sells the OEM part for $38
    Aug 16 2020
    Q
    I had the same code a month ago, it turned out the fuel pressure sensor on the bottom of the HPFP wasn't even finger-tight. Check the connector on it too, I had issues with that about 3 years ago.
    Feb 14 2016
    S4 Avant
    Thanks y’all. Was able to find on prime for $30 and arrives Thursday. Hopefully this does it, but will check all connectors and associated fuel sensors while in there. Given I’ve been dealing with a fuel rail pressure too low code and now fuel pressure sensor code I’m really hoping this resolves it
    S4 Avant (6MT)
    Jan 04 2021
    BMW x3 28i/ CBR F4i/ YZ125
    CALI
    When was last time injectors saw cleaner? My injectors were sticking open and threw that code initially with my autotech piston.
    Feb 14 2016
    S4 Avant
    I ran a can of BG 44k with my last fill-up, but the last time the injectors were out was roughly 18k miles ago when I did the swap. car is running great, no signs of clogged injectors.
    I just changed out the G247 but still have the P0087 fuel rail pressure too low code. At this point, Im blaming the tune (VPS). The owner is being a shithead and blaming components, but at this point ive changed the lpfp to walbro 450, replaced the auto tech hpfp back to a different stock hpfp, and have now changed the g247 sensor. Ive been trying to figure this cel out for almost a year now, and VPS will not admit its their tune (the CEL started immediately after final revision tune), so I think im just going to go back to IE and figure out an o2 spacer combo to get rid of the cat CEL
    S4 Avant (6MT)
    Senior Member Three Rings JRYtheS4's Avatar
    Sep 08 2020
    When you do find a combo.. let me know. Going to a similar setup soon on IE.
    Sent from my SM-G991U1 using Audizine Forum mobile app
    2011 Audi S4 Prestige 6MT|Full ADS w/ sport diff|Meteor Grey Pearl|Black/silver alcantara|Aluminum trim
    Bone stock except intake
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    Running a low fuel pressure code for a year is not the smartest thing I've read on the internet today.
    Feb 14 2016
    S4 Avant
    Quote Originally Posted by f1torrents View Post
    verey insightful, thank you
    S4 Avant (6MT)
    Jan 04 2021
    CALI
    It would be very difficult for the tune to create a rail pressure P0087 issue. Because even if the tuner did some wacky stuff like keep the regulator valve closed improperly, the fuel pump would still be creating fuel pressure since its output is directly a function of rpm.
    Since you did the Walbro mod, are you able to log and see improvement? Maybe issue with the lpfp that doesnt trigger ecu fault, but doesnt feed the hpfp properly throwing that code first?
    Feb 14 2016
    S4 Avant
    well, I flashed back to IE dual pulley and ripped it home and scanned...no soft codes, and p0087 would always come back after a hard drive, so it does appear to have been tune related. will be getting some more miles in shortly to confirm
    S4 Avant (6MT)
    Feb 14 2016
    S4 Avant
    Confirmed: it was the tune
    S4 Avant (6MT)
    Sep 16 2020
    West Michigan
    I am not familiar with VPS, could you provide a little more information on them for those of us whom are not in the know?
    Aug 16 2020
    Q
    Sounds like those fucking scammers at Eurodyne. I went through hell with them for months until I said fuck it and dumped another load of $$$$ at 034(which immediately fixed ALL the issues). Eurodyne sells shit products and their "support" is nothing more than "our tune worked on another car, so the problem must be your car". Fuck Eurodyne, don't buy anything from them, ever. If anyone from ED sees this, go ahead and post up your reply, or refund my $1,100 and I'll think about removing this post. I don't even have the stomach to sell this shitty tune and cable to someone else, or even give it away.
    Feb 14 2016
    S4 Avant
    ya it was some bullshit, zero follow up from the tuner and would never accept responsibility that it was the tune causing the code. the tune was VPS (verstarkt performance systems) they're one of the few custom 3.0 tuners around. my shop had become a dealer and convinced me to switch over. it was fine at first and everything was dialed, but after the final revision the code immediately popped and the tuner was blaming lpfp needing to be upgraded. did that, still the same issue and started blaming other components. reached out via phone numerous times and left multiple VMs along with emails over the last year to change parameters or find a solution but still have never gotten a response back. switched back to me IE tune yesterday and the car is running cherry with zero CELs
    S4 Avant (6MT)
    Sep 16 2020
    West Michigan
    Verstarkt sells that Whipple supercharger kit for these cars.
