Results 1 to 14 of 14
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    Small coolant leak
    Is there any reason not to add a can of Stop Leak?
    Old Geezer, formerly known as Stud Muffin
    Veteran Member Four Rings Zolli's Avatar
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    I seem to recall the copper flakes become problematic. I dunno. Where’s the leak? Or is it currently a mystery?
    I'm still listening for that rattle!
    If it rattles, it's because I baby it.
    B7 S4 25Quattro
    Jun 18 2010
    East of Cincinnati
    A mystery!
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    Personally, I’d just keep topping it off until it becomes more evident
    B7 S4 25Quattro
    Jan 29 2017
    B7 RS4, B15 Sentra Spec V
    San Antonio, TX
    Leak detector kit that comes with a light.
    Radiator end caps?
    Veteran Member Four Rings Rol-co's Avatar
    Dec 12 2020
    Europe (NL)
    Still have one too, its drippin at the bumper, motor guard is bone dry.
    Radiator end caps? They are at passenger side? Bottom radiator tower is wet.
    Only milk and juice come in two liters, "05 S4 B7 tipt Avant phantomschwarz/schwarz
    Junior Member Two Rings
    Sep 25 2022
    Houston
    I would not use stop leak. It can mess up a lot of stuff. I've worked on quiet a few cars after stop leak was used, and the junk in the inside of the cooling system was nasty.
    Jun 18 2010
    East of Cincinnati
    Seems like it only leaks when the system is under pressure...
    Sep 25 2022
    Houston
    You can get a coolant system pressure tester (radiator pressure tester) and pressurize the system when the car is off to help you find the leak. They're about $50-$100 on amazon or at harbor freight.
    Jan 29 2017
    San Antonio, TX
    Quote Originally Posted by sid33 View Post
    Rent it from an auto parts store.
    May 12 2008
    2004%20audi%20s4%2C%202003%20a4%2C%201999%20a4%20avant
    freeport, ny
    Pull out headlights and check corners of aux rads for leaks. Also much more visibility for coolant hoses behind headlights. Coolant bottle/ expansion tank is more than likely the culprit. Unscrew it with the hose attached and take a look at the bottom/rear portion, they usually have stress cracks that weep under pressure. Stop leak is a band-aid. Keep the search going and if all else fails get a pressure tester like the others said.
    Dec 12 2020
    Europe (NL)
    I can tell you its hard too find, even with a pressure tester (i have one), its leaking at the bumper but can't tell where its coming from. Sometimes you need too pull a lot of parts off.
    Expansion tank is alway's a neat idea, a new one is not to expensive and look great at the motor compartment.
    Nov 22 2013
    San Francisco
    If you have red/pink or the purple coolant g12 or g13 it should have uv dye in it. You can shine a uv flashlight around the engine bay and find the leak.
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    +1 on the aux radiators....leaky bastards.
    B6 S4, B8 A4, 8P A3, and something, something.
