Few questions - I'm new to owning an S8 and love the thing. But have a few questions about replacing/repairing/rebuilding certain things on the car
Steering/Suspension:
- I know there are service kits for them, at least I see a lot around when looking it up, but I am curious to know if anyone here has successfully rebuilt one of the power steering racks that are fitted to the S8. What was it like, would you recommend it, did you use a service manual or go at it with self documentation, (if yes to using a manual) where did you get it at/from?
- Does anyone have or know how the variable steering system works? Can it be adjusted through tuning?
- Has anyone installed polyurethane bushings on the suspension? PowerFlex offers these and wasn't sure if anyone has experience with them on the D2. I've used the same make on other cars.
Engine/Transmission:
- The RPMs waver at ~2000 in 5th gear while cruising at 50mph with light throttle (enough to maintain speed on flat ground). The car shifts fine(ish) (3rd to 4th is smooth but very noticeable), and above 50 seems very steady. Would this wavering be caused by the TC or is this a gearbox issue? I was told it was rebuilt by ZF within the last 10 years and has less than 40k miles on the box.
- Has anyone rebuilt/refreshed the valve body? Car is reading close to 160k miles on the dash and it may be nice to give it a refresher.
- What exactly does ZF replace/rebuild on their transmission services/refurbed units? Clutches, gears, valve body, pump, etc.
- Like mentioned above, RPMs waver at ~2000rpm - could this be caused by the secondary runners in the intake opening/closing when they shouldn't be? Its pretty noticeable feeling and have no way of logging that (unless someone can tell me that would be sick). Maybe by using the maf?
- After a normal drive/commute (20-30 miles) when the car is put into reverse there is sound coming from inside the car that sounds like a muffled bottle of rocks being thrown around. You cannot hear it from outside the car, but only the inside. Could this be the TC? Engine or Transmission mouts? Something normal?
- Using VCDS how can I monitor/log TC activity, Trans oil temp, and anything else I should be looking at? Just need the group numbers.
The car has no CEL and checking with VCDS there is no codes anywhere related to engine, transmission, steering, or suspension. I love this car and its been beyond impressive until within the past few months. I am slowly loosing confidence in driving it and I feel I am slowly turning into an old insane man who fancies a tin-foil hat. I just (like 40 minutes ago before posting this) logged the Absolute Throttle Position, RPM, MAF, and load. Hopefully that will lead to something.
Any response related to what I asked is great. I want to enjoy this car as much as I can and right now every drive has been radio off and freaking out over every little thing. Mind you I own a built S4, and I have more confidence in taking that on a 1000mile road trip than I do with this here S8, so I am well aware of the life that comes with owning this era of Audi.
