Results 1 to 9 of 9
    Junior Member Two Rings damienhou's Avatar
    Oct 11 2020
    Cupertino, CA
    Proper tire pressure on PZero 22"?
    Hi folks,
    I just got my car back from its first service today and noticed that the dealer put the cold pressure to 43.5psi. According to the door card cold pressure should be 49 though so I'm confused. These are PZero on 22".
    Veteran Member Four Rings FBAnder's Avatar
    Mar 05 2020
    Chicago Metro
    49 is for max load on 22s with 190mph top speed. I would not be driving around at that pressure normally. Check the manual for recommended pressures and tweak as desired. Page 269.
    FWIW I usually run 39 to 40.5 PSI on the 22s and 40.5 to 42 on the 21s for winter. Run winters a little higher to account for outside temperature drops.
    edit for clarity
    Oct 08 2012
    Bloomfield Hills
    Yikes I never follow the cold pressure on the door on any of my vehicles. Look at manual for proper normal load pressure. I ride 38 psi on my summer Michelins and winter Vredestein tires..
    Aug 27 2007
    RS6, A7, CTS-V Wagon 6 speed
    Jacksonville, Florida
    Interesting as my door sticker reads 41 psi.
    Mar 05 2020
    Chicago Metro
    Quote Originally Posted by tinmanwpk View Post
    That's recommended max load psi for 22s at 155mph top speed IE steelies with air suspension.
    Oct 10 2022
    Midwest
    I run mine at 36psi cold.
    Aug 27 2007
    Lol, I guess I have to RTFM!
    Established Member Four Rings Jimminez's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    In case the vehicle didn’t come with the manual.
    Oct 11 2020
    Cupertino, CA
    Thanks! Time to RTFM for me.
