JHMotosports is proud to offer a complete performance based braking solution for the C7 A6-A7! Our JHM Lightweight Rotors have been proven over the many years of testing to be a cost-effective performance based solution to expensive OEM rotors.
The full front and rear package equates to an astonishing 33LBS of rotational weight savings!
JHMotorsport Front 2-piece Lightweight Rotors Specs:
Fitment:
-Direct Replacement for OEM # 4G0615301A Cross Reference 4G0615301T
-C7 A6-A7 with 356mm Front Rotor
Stock vs. JHM
-Rotor Weight: Stock = 30.25lbs(each), JHM = 19.5lbs(each) - 30% LIGHTER, 11lbs less each
-Rotor Cooling Air-gap: Stock = 13.06mm(.514"), JHM = 18.2mm(.716") - LARGER for better cooling
-Rotor Cooling Center Fin Design: Stock = Straight Fin, JHM = Directional, specific left and right-side design- MORE EFFICIENT for better cooling
-Rotor OD: Stock = 356mm(14.01"), JHM = 356mm(14.01") - SAME
-Rotor Thickness: Stock = 34mm(1.34"), JHM = 32mm(1.26")
-Bolt pattern: - SAME (fits like an OEM rotor would)
Shaves 22lbs of unsprung weight from the front of your car while increasing braking performance, plus they bolt on just like stock! This is great alternative to a full on Big Brake Kit since the stock C7 A6-A7 is a stout 356mm and most may not want to spend $2,000 plus for a full Big Brake Kit. It is also a great alternative to those drag racing who are considering going to a smaller rotor and caliper setup while not losing any braking power.
FRONT ROTORS AVAILABLE HERE: https://jhmotorsports.com/front-roto...nt-rotors.html
JHMotorsport Rear 2-piece Lightweight Rotors Specs:
Fitment:
-Direct Replacement for OEM # 4H0615601Q
-C7 A6-A7 that came factory with a 330mm rear rotor.
Stock vs. JHM
-Rotor Weight: Stock = 17lbs(each), JHM = 11.5lbs(each) - 32% LIGHTER, 5.5lbs less each.
-Rotor Cooling Air-gap: Stock = 6.35mm(.250"), JHM = 13mm(.511") - LARGER for better cooling
-Rotor Cooling Center Fin Design: Stock = Straight Fin, JHM = Airfoil - MORE EFFICIENT for better cooling
-Rotor OD: Stock = 330mm(12.9"), JHM = 330mm(12.9") - SAME
-Rotor Thickness: Stock = 22mm(.866"), JHM = 22mm(.866") - SAME
Shaves 11lbs of unsprung weight from the rear of your car while increasing braking performance, plus they bolt on just like stock!
REAR ROTORS AVAILABLE HERE: https://jhmotorsports.com/rear-rotor...4-a8-3-0t.html
VIEW ALL AVAILABLE OPTIONS HERE: https://jhmotorsports.com/catalogsea...7+a6-A7+rotors
