Results 1 to 15 of 15
Hybrid View
    Established Member Two Rings EuroTrA4sh's Avatar
    May 24 2007
    Columbus, OH
    How Strict are Smog / Emissions Test in Colorado?
    Hey everyone,
    Just moved to Denver from out of state and about to go through car registration process and the whole bit. I have a 2016 audi sq5 with Awe downpipe, exhaust, APR carbinio intake and 034 tune.
    Should I be worried about not passing visual inspection or any tests with my mods?? Thanks in advance!
    Sent from my SM-S906U using Audizine Forum mobile app
    Veteran Member Four Rings Docwyte's Avatar
    Feb 02 2005
    '03 911 Turbo, '15 Cayenne Diesel
    Yes. Does your downpipe have cats? If not, you're going to fail. Flash the car back to stock, if you bring it in with the tune you're going to fail.
    '15 Porsche Cayenne Diesel ** Wifes DD
    '03 Porsche 911 Turbo 6 MT **
    '18 Land Cruiser ** My DD
    '17 KTM 690 "Adv"
    Junior Member Two Rings Chimpzilla's Avatar
    Jul 13 2004
    Yellow 1958 Buick Special
    Colorado
    Maybe they treat a 20 year old car different but I was there the other day with my S4 and they barely looked at it.
    B5 S4 Imola Yellow Avant - 8Y RS3 Python Yellow Sedan
    May 24 2007
    Columbus, OH
    Yeah I have AWE downpipes & exhaust. I just checked their site and for both products, it says they're good in 50 states. Maybe I'll give Burg Performance a ring and pick their brain. I see that they're a 034 tune shop, so they may have experience in the tune being good or not for emissions testing.
    Junior Member One Ring
    Jul 28 2021
    2015 Audi RS5, 2016 Audi SQ5, 2004 Honda Pilot, 2008 Volvo S80
    Colorado
    Berg Performance
    Quote Originally Posted by EuroTrA4sh View Post
    Berg is AMAZING, and I highly recommend them!! They have taken great care of me and my Audi's (RS5 and SQ5)
    Feb 02 2005
    Unless the tune is CARB compliant it doesn't matter. Flash it back to stock, make sure the readiness monitors and set and then try to smog it
    '17 KTM 690 "Adv"
    Veteran Member Three Rings PassionForAudi's Avatar
    Aug 10 2016
    4M.5 SQ7, B8.5 A4 (hey, I keep it clean, though!) and 5th gen’ Ram 3500 Limited Mega Cab (DRW).
    Orange County/Inland Empire, C
    Quote Originally Posted by Docwyte View Post
    Let’s just say that for whatever reason a tune us detected and you fail due to that, does that log get sent out to the DMV automatically or do you just keep trying without the DMV figuring things out?!
    #AudiForLife
    Feb 02 2005
    You get sent to the smog referee where they're going to go thru your entire car with a fine toothed comb. It's the same process as when I had my LS swapped 944 inspected and made legal for smog here and they were quite thorough...
    '17 KTM 690 "Adv"
    Veteran Member Four Rings zatch_303's Avatar
    Jun 13 2009
    Colorado
    Pretty strict here.
    // 2001.5 Pearl White B5 S4 Sedan 6MT
    Sep 10 2018
    N.W colorado
    I depends where you are and what county you actually live in. Where I’m at on the western slope, there is no smog test requirement. When I lived in boulder, I had to get tested every couple of years. Not sure if it’s the same for the entire front range, or just certain counties. I know when I bought my Tacoma, it had an emissions test exemption sticker on the windshield. Bought it brand new and was living where i am now, so im not sure if that had to do with the sticker or not.
    Established Member Two Rings caelric's Avatar
    Jun 10 2023
    Colorado Springs, CO
    Quote Originally Posted by Rkymtnrider View Post
    no emissions testing down in El Paso County (Colorado Springs) at least.
    Veteran Member Three Rings Aok303's Avatar
    Jul 11 2012
    Bicycle bicycle i want to ride my bicycle
    Lakewood-Morrison / Colorado
    my s4 has same set up and ive passed no issues
    i have a different turn as long as all of your smog are not tuned out you will be fine. alot of us last year had to get a modified file to pass the scan.
    they awe downpipes have a bump so they will pass visual
    2016 Noggy S4 - Stock and loving it.... Jk its not stock
    Mar 06 2023
    2019 RS5 SB, Supercharged 2018 4Runner
    Castle Rock, CO
    Quote Originally Posted by Aok303 View Post
    Just curious if they passed it with an aftermarket tune then? or did you need to flash back to stock? Debating on doing a tune but don't want it to cause lots of hassles when emissions check does eventually come around for me. I have run my G35 through emissions with a tune before and no issue.
    Active Member One Ring richy3's Avatar
    Feb 07 2023
    CO
    Hi folks. I have a '16 RS7 and I passed all the OBD/smog/gas cap checks in Denver County (the strictest county) with an APR Stage 1 tune. No other mods. I'm posting this to let everyone know I DID NOT go to APR and flash back to OEM Audi tune, I simply switched the tune to "Stock" from the cruise control lever and I passed! No issues at all! Also, my RS7 was not put onto the AWD rollers, the testing folks mentioned that cars 2013 and newer do not do the roller/dyno. Your mileage may vary, but I'm very happy my tune was not detected. Kind reminder to vote against stricter emissions laws in Denver county in the future. Any questions don't hesitate to ask me. Cheers.
    Mar 06 2023
    Castle Rock, CO
    Quote Originally Posted by richy3 View Post
    Thanks for the update!! I am looking at the 034 tune myself for my rs5. Good to know "flashing back to stock" would fix any issues and pass emissions.
