Originally Posted by
Rcryan7
Don’t worry I looked it up thanks , so wires are touching , I don’t want to cut the harness protecting but I think I will be able to seal it back up OEM
Thanks
I could only think they would be touching somewhere or I also heard it could be a bad ecu, are you referring to the coil packs themselves ?
For my car, the primary culprit was the body side of the crank sensor harness - 3 pin plug right under the coolant overflow. It was brittle, which causes the copper strands of the wire to become exposed, and then once 2 of those touch, it’s an immediate short. Another somewhat common thing is again, that same area, where the engine harness goes to the ecu, there are 1 or 2 studs on the firewall. Over time and again due in part to heat, the harness rubs the stud, and causes the insulation of the wire to erode, and it will also cause shorts.
What I did was basically as described in my thread: I removed the coolant bottle, and inspected each wire in the general area one by one. I fixed every single area where there was exposed wire or where the wire insulation was very worn. But the main solution to my fuse 29 issue was the crank harness itself. For that I replaced the car side of the plug completely with a new one, 3 fresh wires spliced in, and it was done.
