Results 1 to 3 of 3
    Mar 03 2004
    2014 Allroad, 98 A4 2.8, 00 S4, 03 3.0L A4
    Chelsea, MI
    Hard Starting 2014 Allroad
    I push the button to start the car, and it just cranks and cranks. As soon as I pump the accelerator, the car starts and everything is normal.
    I assume that it isn't a fuel pump problem. A fuel pump either works or doesn't.
    It might be a restricted fuel filter.
    Or is there some other relay that isn't allowing enough fuel to the injectors with no accelerator input?
    Thoughts?
    Thanks,KK
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    Real allroads have no stinking buttons to start :). Proper solution to this issue, is to sell you fake allroad, and buy the real one, made between 2001 and 2005.
    Established Member Two Rings Dinsdale's Avatar
    Jan 17 2020
    Stage 3 allroad, Old Dodge Cummins
    Texas coast
    Quote Originally Posted by V1nny View Post
    V1nny is correct. They don't have a puss start button. Real allroad's are started with rage and a closed fist. They also have 2 massive turbochargers, 3 pedals and a MANual gearbox. The fake, only a shiny starter button that laughs at you, 1 wee little hair blower and an automajic gearbox.
