Results 1 to 11 of 11
    Senior Member Two Rings Diesel_A4's Avatar
    N/A
    Silly intake question
    Installing an EVO ms intake on an 01.5 and on my stock airbox there is a hose that runs into the airbox, is this of any use?! I cant figure out if its possibly a smog pump? Where the small air filter would have to go? Or if its just there in case something somehow gets in the airbox its like a run-out for it.
    Thanks
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    It is for the secondary air pump, the kit should come with a filter that goes on that tube.
    2006 Audi S4 Avant
    Lowell
    Hook it up or you will start throwing check engine codes.
    ------------ _-~Kirath~-_---------------
    2016 Kia Optima SX-L -
    2006 Audi S4 Avant
    Veteran Member Four Rings 1 ate T's Avatar
    VW Jetta GT, 01 Eclipse GS
    Newark,OH
    +1 and you will probably be chugging.
    2000 A4 1.8TQM - Sold
    Will be back in an Audi this summer!
    N/A
    anybody know what size the small filter is?! I didnt happen to get one so im gonna go to autozone and get any generic small filter.
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    they are all standard size however i dont think any of the filters from autozone are going to have the same diameter hose to connect onto the a4. for some reason autozone carries the smaller diameter hose and the audi filter requires larger. this may have changed.
    Veteran Member Four Rings audisnapr's Avatar
    Jun 06 2004
    1993 Ford E250 Sportsmobile, 1990 Corrado w/ VR6 swap track car, 2011 Mazda3 S Sport 5dr
    nope niz, you are correct - I have never seen the right size filter from autozone - it's always that tiny little 1/4" opening ones.
    Jul 07 2004
    socal
    Well you could always call up Evolution Motorsports and see if they will sell you the small filter, other wise you could always cover the inlet with a screen since it only sucks in air when the pump comes on and that is usually only during cold idle.
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    b/c most people use them for valve cover venting
    concours show prep in the DC metro area
    turbos, rods, pistons, clutches, etc.
    Veteran Member Four Rings BranCKY3's Avatar
    Mar 08 2005
    Greenville, SC
    I just wrapped one of those in electrical tape and shoved it into the air pump hose, hasn't fallen off yet, it's been almost a year.
    2016 Audi S3
    Feb 13 2004
    Lakewood, CA
    ^^^^^ hahaha home depot mods. gota love em.
