Results 1 to 7 of 7
    Junior Member One Ring
    Nov 10 2020
    El Paso
    MMI SW update HN+_US_AU3G_K0942_6 troubles
    Hoping someone can help me out..
    I have a C7 A6 currently equipped with mmi sw “HN+R_US_AU_P0733” and mu 0810. I’m trying to update to the current sw version stated above in topic via a brand new 32G SanDisk SD card formatted to Fat32. I unzipped the file and everything looks good so I go to install the sw onto the mmi but every time I press update it returns with “medium currently unavailable”. I’ve tried both sd slots along with re-installing sw to Sd card numerous times but still no luck. Any pointers or info would be much appreciated.
    Update
    Just thought about this as I’m relatively new to all the software related things..
    What’s the difference between the HN+R_US_AU_K0942_3, and HN+_US_AU_K0942_6?
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    Quote Originally Posted by Tj_58 View Post
    Update
    OK, so you know how to start the Red Engineering Menu (REM), which reports the current "train" and MU software version.
    This generation of MMI system has essentially two variations: MMI 3G (HNav), and MMI 3G+ (HN+). The B8 (A4, A5, Q5, Q7) platform MMI 3G+ uses HN+_US_AU_K0942_6 software, while the C7 platform (A6, A7, A8?) uses HN+R_US_AU_K0942_3. Thus, you need to prepare an SD card with HN+R_US_AU_K0942_3 for your C7 A6. I have more info on this over here: https://www.vwvortex.com/threads/aud...tware.9471271/
    Once you have the MMI software updated, you can consider updating the navigation database, too: https://www.vwvortex.com/threads/8r0...-data.9477077/ --g
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Nov 10 2020
    El Paso
    Thanks for the reply I really appreciate it. So I downloaded the K0942_3 and I ended up with the same results. It keeps telling me that “the medium is currently unavailable” after trying to read the release info.. I don’t know if at this point if my mmi is just refusing to read the sd or what. I checked dtcs in my GEM and there were a bunch in “untested dtcs” but none in “qualified dtcs” not really sure what the difference is..
    Aug 31 2014
    NW OH USA
    Generally, "the medium is currently unavailable" in the REM suggests that your SD card is either not FAT32 or you didn't extract the archive to the SD card properly.
    The REM Software Update process expects to find plain-text file metainfo2.txt in the root/top directory of the update media (SD card, USB flash drive, DVD, etc.). For the HN+R MMI software update, you should have two files (finalScript, metainfo2.txt) and 45 directories in the root/top directory of your FAT32 SD card.
    BTW, someone else was asking about this recently, too: https://www.vwvortex.com/threads/8r0...post-115790804 --g
    Nov 10 2020
    El Paso
    Awesome I really appreciate it man I’ll look more into it.
    Oct 26 2019
    NC
    I am getting the following errors when extracting nav databases to my SD card. I've tried to re download the files from Drive just in case, but it takes hours and I still get the same error during extract.
    I don't have the same problem with the MMI firmware update. Is something broken in the google drive files? Could they have gotten corrupted?
    Windows file extractor straight up gives an error and crashes. 7zip will extract the nav databeses but with errors like this:
    Headers Error
    Missing volume : 8R0051884JE-common.part3.rar
    Data Error : pkgdb\TER3_NAR\86_DTM_3G_NT_NAR.4_4.2.ATLAS
    Data Error : pkgdb\TER_NAR\86_DTM_3G_NT_NAR.4_4.0.ATLAS
    I can't post a screenshot for some reason.
    Aug 31 2014
    NW OH USA
    @GripB85 -- When you download my multi-part 8R0051884JE archives, you must download each RAR part separately -- do not download the entire set as a single ZIP file. That said, begin with the Common set and extract with 7zip. Then fetch either the MMI3G or MMI3GP set (or both, if you want to entire distribution), and extract again with 7zip.
    To post a picture here with the browser interface, you need to use the "Go Advanced" button and attach the uploaded image within the post. --g
