Hello all, I seen that this issue has come up in previous threads. Hoping some recent advise has been posted. So I just replaced my motor, installed new motor mounts, and replaced the clutch while doing swap. I just purchased South Bend stage 2 friction disc and pressure plate, and aluminum ECS flywheel. This was the kit on sale over the holidays at ECS. Installed clutch while the engine was out, and trans still in vehicle. Also removed slave cylinder out, before installing clutch. Furthermore, changed clutch line to steel braided line. Bled clutch. Car all back together, fired up no problem. Bled coolant, top everything up..etc. Car ran smooth throughout bleeding. While parked, clutch pedal smooth, when through gears. Np. Drove out of subdivision, everything good, great feel on pedal. Drove for about 10 more minutes, clutch pedal was solid, pushed a few times, cat started shifting great, pedal smooth. It repeated again, applied pressure, clutch went down.
Stopped at lights, in nuteral, went to hit pedal, it was solid. Pressed a few times; still solid. So I pushed hard on it, and pop, right to the floor. Car wouldn't move. Towed home to shop. Car now won't start with pedal on floor, dash message telling me to push clutch to start. Pulled slave out , pushed it in manually, but had to go to pedal to pull up by hand. Had friend push pedal and slave extended.
I am assuming the clutch hung up on input shat, thoughts? Perhaps the slave failed, master failed( considering no start) and input would help before I yank tran out.
