    Oct 19 2022
    LI, NY
    ‘17 S3 disable cornering lights?
    So, I have a ‘17 S3 (facelift) which has the cornering lights that come on in turns. One of them is not working and instead of buying a new headlight, for now I’d rather just program it out. Is this possible?
    Dec 25 2004
    Earth
    You have VCDS?
    It maybe possible but you need an OBD reader than can see the headlight modules and be able to code them...
    You might even need ODIS to eliminate items...
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Oct 19 2022
    LI, NY
    Quote Originally Posted by MikTip View Post
    You have VCDS?
    I do have VCDS
    Dec 25 2004
    Earth
    Quote Originally Posted by Jcway16 View Post
    I do have VCDS
    Then use VCDS see if it lets you disable the corner lights
    Nov 27 2020
    Florida
    Coding below might help. I used it to make fog lights do the Adaptive turning.
    Module 9 central electronics
    Adaptation 10
    Adaptation channel: (5) leuchte 12nl lb45-lichtfunktion b 12
    Set to not active
    Adaptation channel: (5) leuchte 13nl rb5-lichtfunktion b 12
    Set to not active
    Adaptation channel: (2) static afs light-vorschrift
    Set to off
