Results 1 to 4 of 4
    Veteran Member Three Rings kevin#34's Avatar
    Aug 11 2019
    Rome, Italy
    silica bag inside coolant tank ???
    quite surprised after having watched this video (I have never heard or read about that), so checked my TT-RS coolant tank, and yes, there is a silica bag inside
    https://www.youtube.com/watch?v=t1ia1ybgUt4
    what do you think guys? (there are several people stating their bag got broken, letting the silica damaging the cooling system...)
    2020 TT- RS
    ex 2018 TTS
    Jul 21 2014
    United States
    Designed to prevent sloshing and spuriously tripping the overfill/underfill sensors presumably.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by GTItoS4 View Post
    "From one of VW's Self Study Program 514 page 31:
    Coolant Expansion Tank with Silicate Repository
    The coolant expansion tank contains a silicate repository. Silicate is used to protect the aluminum components in the coolant
    system from corrosion. There are silicates in the G13 coolant, but they are used up over time if the engine is subject to high
    thermal loads.
    To compensate for the silicate consumption, silicate is taken from the repository and added to the coolant. The silicate
    repository provides additional protection against corrosion for the aluminum components in the coolant system over the entire
    lifespan of the engine."
    Stage 1 more than you RS3
    Jul 21 2014
    United States
    Neat. Don't remove lol.
