Results 1 to 4 of 4
    Jan 30 2023
    Newtown, PA
    B8.5 to B8 Compatible Parts Question
    Hi all,
    I recently purchased a 2011 B8 S4. It needs some work and curious if I can source some of those parts from a B8.5. Here's what I need to replace.
    Rear Bumper: If sourced from A4, would need the dual exhaust diffuser, but otherwise works?
    Rear TailLight: OK if A4?
    Full rear suspension (Cv axle, control arms, tie rods, springs, etc) all of it. WOULD ONLY SOURCE FROM A B8.5 S4.
    S4 would only source the suspension (if possible), but could I get A4 for others?
    Am I correct to takeaway that it's only related to the front-end?
    Thanks for any advise in advance.
    Established Member Two Rings 613b8s4's Avatar
    Jun 30 2022
    2011 6MT S4, 2021 Explorer ST
    Ottawa Ontario
    generally none of the lights/body will be able to work with the b8 from the b8.5 suspension should be ok but check with part numbers... audiaccessories.ca is a good site to reference part numbers
    2011 6MT PHANTOM BLACK PEARL, 034 STAGE 2+ WMI 034 INTAKE 034 MOTORSPORT ENGINE MOUNTS 034 DRIVETRAIN MOUNTS BILSTEIN B8 SHOCKS 034 STRUT MOUNTS H&R SPORT SPRINGS CTS HX CTS CATBACK EXHAUST CAP TEST PIPES CAP V2 CARBON DIFFUSER CAP HIGH KICK CARBON SPOILER iABED THROTTLE BODY JXB SS INSTA: @613_B8S4
    Jan 30 2023
    Newtown, PA
    Thank you. Do you know if the B8 A4 rear bumper will fit on the B8 S4 WITH a different diffuser to accomodate quad exhaust?
    Feb 18 2008
    LI, NY
    if you are interested I have a brand new carbon fiber Deval Diffuser for B8 S4
