Results 1 to 25 of 25
    Senior Member Three Rings JimmyS3's Avatar
    Aug 13 2016
    Pennsylvania
    Coolant shut off valve replacement
    So I just noticed that I have a leak coming from the coolant shut off valve. Looks like it cracked at the top.
    Has anyone else had this happen?
    :: 2018 S4 ::
    - 034motorsport - APR - CTS - EMD - ECS - MBRP
    Jan 26 2019
    Yep. Happened to me. Audi replaced it with no issue.
    Mar 20 2020
    New Jersey
    Quote Originally Posted by JimmyS3 View Post
    Just replaced mine last month, upgraded the thermostat and seal while I was in there.
    That requires a special tool though...
    Mine failed and the whole top part of housing was cracked.
    Sent from my SM-S908U1 using Audizine Forum mobile app
    Senior Member Four Rings
    Nov 20 2021
    United Kingdom
    Very common on these but I don’t think many people bother to change it due to how little it usually leaks.
    Most people wouldn’t even realise unless they looked at it. You’re probably fine to leave it as is unless you start noticing coolant loss.
    Aug 13 2016
    Pennsylvania
    Quote Originally Posted by AldermanToffee View Post
    What drove me to look was coolant smell for a while but nothing wet up until now. Levels all look good just my fear is having my kids in the car and getting stranded, that wouldn't be to good.
    :: 2018 S4 ::
    Junior Member Two Rings
    Feb 08 2021
    SC
    JimmyS3, do you have a shot a bit further back? I am trying to locate. Thank you.
    Aug 13 2016
    Pennsylvania
    Does anyone have a part number?
    :: 2018 S4 ::
    Mar 20 2020
    New Jersey
    06M-121-678-H
    Aug 13 2016
    Pennsylvania
    Quote Originally Posted by East_Coast_S4 View Post
    06M-121-678-H
    U the man! Thanks
    :: 2018 S4 ::
    Jul 11 2022
    Illinois
    Wondering if I'm in the same boat as you. I bought the car used back in June as a CPO. Had some things looked at at an indy shop, they said my coolant was low so they topped off in October. I just topped it off again with about a cups worth of coolant to keep it close to max and above min.
    I have no coolant smell and couldn't see much around water pump or thermostat, but I did notice some white residue around the same part you're having issues with. I'm unsure if it's just road salt or dried up coolant.
    I'm curious if I could be losing that much coolant from the shut off valve. I will be monitoring the levels closely to see if it drops more. Sucks because I was about to tune the car but going to hold off. 20230228_123803.jpg
    Sent from my SM-G998U using Audizine Forum mobile app
    Aug 13 2016
    Pennsylvania
    Quote Originally Posted by Jrbball7 View Post
    So the part my shop ordered was wrong and the new part has been ordered. They asked if I wanted to try a Liquid Molly solution in the time being and so I did. Cleaned the part and drove it home and couple trips with no new smell. So once the part comes in debating on swap or wait till I see the leak/smell again.
    Mar 08 2018
    Queens ny
    Anyone has a write up on how to change this part? Or is it easy to do? Or do you guys recommend a shop?
    Mar 20 2020
    New Jersey
    Quote Originally Posted by DsgDame View Post
    Remove front clip, swing ac condenser to the side, remove charge pipes and you're there.
    Not hard but not quick and easy either.
    If you can replace the FMIC and Charge pipes you can swap this.
    Mar 08 2018
    Queens ny
    Don’t sound too bad, might just wait until I get FMIC and charge pipes and do everything at once. Thanks for the tip because shops in ny prices are getting crazy
    Sep 07 2022
    Scotland
    Hi bro, did the liquid moly suggestion hold up in the sbd tempted to do the same
    Aug 13 2016
    Pennsylvania
    Quote Originally Posted by Bicepbraha View Post
    So far no issues but I really drive the car. I put maybe 75 miles on it since I put it in.
    May 23 2020
    Boulder, CO
    I know this is an old thread, but I have this valve leaking and most everyone online says this 100% means the water pump is leaking too. Have you seen this valve fail on its own frequently without the water pump failing?
    Aug 13 2016
    Pennsylvania
    I haven't replaced it or the water pump. Still going strong and probably put 12k miles on.
    I keep an eye on it though. I am tired of the VW/ Audi water pump issues.
    Apr 13 2021
    Orlando Florida
    Is it easier to access the valve from under the car or remove the front bumper?
    Veteran Member Three Rings JonnyBravo!'s Avatar
    Oct 26 2014
    2018 SQ5 | 2017 A3 e-tron
    California
    Quote Originally Posted by ZakB7A4 View Post
    Check your solenoid valve (top passenger side) - if there's coolant leaking out of it, your waterpump is cooked.
    Quote Originally Posted by LenS4 View Post
    You can't access the valve from under the car.
    Apr 15 2025
    Land of 10,000 Taxes
    So I am a lurker with a Macan that has this engine (EA839?), and this problem that I plan to tackle in a month when my work slows down. I came to Audizine because Porsche people usually don't like to get their hands dirty and don't ever try to fix anything and I figured if any forum had the experts it is this one. I just have a couple questions for those who have done this (and I plan to swap water pump, thermostat, and serpentine belt):
    First, what is the process for the resetting the belt tensioner for the serpentine belt? Is there a tool from Audi? I don't know how to reset it and put a pin back in or should I just swap a new tensioner too?
    Secondly, I don't know if there is a how-to for bleeding coolant. I don't mind picking up one of those pressurized coolant filling kits but I have also seen people post, "run the car with the heat all the way up and feed coolant until full." Are there any bleed valves?
    Any general info threads on this engine, or common issue threads, general pointers on completing water pump/thermostat/coolant valve appreciated. New to Audi engines, but looking to learn. I like to work on my cars when it is not above my abilities.
    Thanks for any help in advance!
    Oct 26 2014
    California
    Quote Originally Posted by DarthTugits View Post
    The tensioner is just cranked 90 degrees to remove/install the belt. It's not that bad. Use a wrench to turn the tensioner and use this pin to hold it in place: https://dieselgeek.com/products/vw-t...dtDE56e4xX5Dec
    For coolant bleeding, I also ran the car with the heat cranked up and the coolant lid off. Haven't had any issues and I've done that three times now.
    The process is really not that bad once you get in there. Message me and I'll send you the service guide PDF.
    Senior Member Two Rings Akakios's Avatar
    Feb 05 2022
    2014 Audi S7 | 2018 Audi S4
    DE
    Quote Originally Posted by JonnyBravo! View Post
    I'll add to this, heat on max, blower on low after a pressure/vac fill works great.
    Deutsche Auto Garage - Website // YouTube // Instagram
    2014 Audi S7 (Audi Exclusive Interior)
    2018 Audi S4
    Apr 15 2025
    Thanks for the info, guys. That is helpful. I asked two local specialty shops (one Porsche, one Audi) what it would cost to do this repair and replace water pump/coolant valve/thermostat and was quoted $4000 and $3000. It looks like a lot of removing the front bumper and radiator, but fairly straightforward. I have a Quickjack being dropped off today and going to take a few days off at the end of May to try this, bleed the brakes, and service the transmission. Wish me luck!
