Results 1 to 1 of 1
    Junior Member One Ring
    Aug 23 2007
    Atlanta (Metro)
    AUDI 3.0T B8 B8.5 C7 Chipwerke PRO Performance piggyback chip tune STAGE II
    ChipWerke Tuning piggyback system for VAG 3.0 TFSI Supercharged Engines
    $200 plus buyer pays shipping
    “Gently Used and Fully Functional. ***Stage II upgrade was performed by Chipwerke***Will ONLY ship to contiguous United States.”
    ***Massive Audizine Thread for research: https://www.audizine.com/forum/showt...ge-2-chipwerke ***
    Chipwerke Website: https://www.chipwerke.com/products/c...33112534515849
    Discover the true power of your vehicle; get better fuel economy and driving pleasure of vehicle, safely, easily and in minutes!
    ChipWerke Tuning piggyback system for has a plug-in upgrade for you! Unlike “ordinary” tuning systems, this unit has been specifically programmed for your vehicle. This sophisticated, microprocessor controlled unit simply plugs in using connectors which are identical to those originally installed by the manufacturer – there are no wires to cut. This means installation is a simple task that will take a few minutes of your time.
    Individually Adjustable Performance
    All boxes come pre-set for optimal power and fuel economy so adjustment is not necessary: you can simply plug-in and enjoy! After figures show the power your vehicle will produce on the provided settings. Max figures show the power your vehicle can produce on a higher setting. Not all vehicles will achieve max figures on a higher setting; most standard vehicles will achieve a power between after and max figures, which is up to 35% more HP and up to 25% more Torque.
