Results 1 to 3 of 3
    Sep 17 2005
    Fremont, California
    Stainless Steel Racing Catalyst Set is Now Available from 034Motorsport!
    The 034Motorsport Stainless Steel Racing Catalyst Set for C8 Audi RS6/RS7 is designed as a drop-in replacement for the restrictive factory catalytic converters. The Stainless Steel Racing Catalyst Set offers increased horsepower and torque throughout the powerband, reduced turbocharger lag, improved throttle response, and an enhanced exhaust note. This upgrade eliminates the primary flow limitation in the factory exhaust system, allowing you to maximize the potential of your turbocharged engine.
    Optimized for increased flow and maximum performance, the Stainless Steel Racing Catalyst Set features two massive Euro 4 racing catalytic converters in the factory locations. This complete drop-in solution includes an integrated v-band flange at the turbine outlets, an integrated oxygen sensor bung after the catalysts, integrated 3-bolt downpipe flanges, and a complete gasket kit to allow for precise fitment and ease of installation. The Stainless Steel Racing Catalyst for C8 Audi RS6/RS7 vehicles is constructed from 304 stainless steel for maximum durability and corrosion resistance, is TIG-welded and backpurged, and includes an integrated OE style heat isolation barrier to minimize exhaust heat transferred into the engine bay.
    For sanctioned racing use only.
    Features:
    • Increased Horsepower & Torque Throughout the Powerband
    • Quicker Turbocharger Spool & Faster Transient Response (150-300 RPM Quicker Spool)
    • Enhanced Exhaust Note & Turbocharger Sounds
    • Direct, Bolt-In Upgrade for Factory Catalytic Converter
    • Engineered In-House by 034Motorsport's Engineering Team
    • Factory-Location Euro 4 Racing Catalytic Converter
    • 304 Stainless Steel Construction with Integrated Inlet/Outlet Flanges & O2 Sensor Bung
    • Precision CNC-Machined Flange Mating Surfaces
    • OE Style Heat Isolation Barrier
    • TIG Welded & Backpurged
    What's Included:
    • Stainless Steel Racing Catalyst Pair
    • 2x V-Band Gaskets Fire Ring Seals
    • 2x OE Gaskets
    Check It Out Here!
    Veteran Member Four Rings PsYkHoTiK's Avatar
    Aug 23 2010
    Redmond, WA
    Any CELs for those of us with stock software (for now)? :)
    Also, any chance you guys are going to make mid pipes as well? :D
    Current: 2022 Audi RS6 | Ultra Blue | 034 Lowering Links | 034 Resonator Delete
    Old: 2017 Chevrolet Corvette Z06 (Z07) | Blade Silver
    Older: 2013 Audi RS5 | Sepang Blue | Eurocode Alu Kreuz | 034 Transmission & Rear Diff Mount | Apikol Diff Mount | Girodisc 380mm Rotors | H&R RSS+ | SPC Upper Control Arms | H&R sways | AWE Track Extreme exhaust
    Olderer: 2011 Audi B8 S4 | Ice Silver | DSG | Sport Diff | APR 93 stage II+ V2
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by PsYkHoTiK View Post
    Unfortunately yes, these will cause a CEL.
    Midpipes are on the way :)
    -Sean@034
