Results 1 to 15 of 15
    Coilovers, which of these would be best…
    ST Coilovers with fixed dampening, Vogtlands, or BC racing. Does anyone have recommendations?
    Which one is most comfortable for a daily driver? I live in NY and the roads aren’t exactly runway tarmac, so I’d value a comfortable ride most.
    Veteran Member Three Rings BucDan's Avatar
    Jul 19 2017
    San Diego, CA
    My vote goes for ST. Why not get the adjustable dampening?
    2013 S4 6MT mods:
    APR intake backpipe w/ modded stock airbox, AFE Air Filter, CTS 187mm crank, APR 57mm charger, APR HX, Stasis Catback, CR-15, 034 Stage 2+/034 Stage 1 CARB
    Quote Originally Posted by BucDan View Post
    Is it worth the extra $200? In all honesty I’m oblivious to what adjustable dampening does
    Sep 16 2020
    West Michigan
    Adjustable damper means that you can stiffen or soften the ride depending on situation or track conditions.
    ST is a quality product, the other two are likely cheap Chinese. (I know BC is Chinese).
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Dampening adjustability provides a great advantage in dialing in the ride to your preference. Def worth it. Basically it changes the behavior of your shock to be more / less firm.
    How low are you looking to go? Carry lots of ppl / cargo? These will be deciding factors as well.
    BCs have the option for a Swift spring upgrade which is a huge improvement over the standard BC springs. Wicked in the corners. Dampers are lower end, prone to being bouncy and will expire faster, esp on your roads. But they're dampening adjustable F/R so that helps out a lot. Def a more sporty option here. Bonus, they're completely rebuildable.
    ST's have a super compliant ride quality but can get a bit out of their depth under aggressive turns in corners. Compliant springs and quality dampers. XA kit has dampening adjustable fronts and possibly rears? (Certain ST kits only offer for the front.) Can't go wrong here.
    Vogtlands are similar to ST although more firm and sporty. Depending on ride height will def effect quality with these (IMO more than other kits) so you need to find a sweet spot. If you're not looking to go super low you'll be fine.
    Veteran Member Four Rings eurojunkjon's Avatar
    Mar 12 2017
    2013 S4
    Burlington, wi
    I have the vogtlands which are from Germany. they ride nicer than my wife’s rs3 with stock fixed suspension. My only issue is the sedan version rear springs are too soft so opt for the avant version instead. I bought the rears from vogtland separately but haven’t put them in yet.
    2013 S4 Imola Yellow / IE Stage 2 / ECS Supercharger Pulley / IE Intake / ECS HX / AWE Non Resonated Downpipes / AWE Touring Exhaust / Vogtland Coilovers / Rs4 Grill / Eurocode SS / Black Forest Shift Knob / BBS LM-R / Alcon BBK / S6 Rear Brakes
    1996 Golf Harlequin #10
    Jun 15 2010
    Chicago
    I ran the ST coilovers for about 60K miles before I replaced them with the BC Racing ones. Used both for daily driving. The first thing I noticed from going stock to ST coilovers was how bouncy the ride became, especially the rear end. The BC coilovers had more of a firm ride but in a good way. My only complaint on those was that the rear would sag if there were passengers in the rear or stuff in the trunk. The ST coils didn't really sag in the rear.
    2010 Audi S4 GIAC Stage 2 | 2007 Lexus IS350 Supercharged
    Sep 16 2020
    West Michigan
    One thing to note on any coilovers.
    Try to find a set that you can adjust ride height independently from spring preload.
    Meaning there should be an adjuster for spring tension AND an adjuster for ride height.
    Mar 31 2008
    eS-4
    CAL*SO
    Solowerks all day!
    Dampening is cool and all but realistically how often do you feel you'd be changing settings?
    Once you start going low your gonna change your driving habits in general to avoid dips and bumps.
    Quote Originally Posted by eurojunkjon View Post
    https://www.urotuning.com/products/v...#collapse-tab5
    These the ones to get? ^
    Also what do you mean by “soft”, is there excessive bounce in the rear?
    Mar 12 2017
    2013 S4
    Burlington, wi
    I replied to your pm, I did order from urotuning and by soft it would rub with the sedan springs on an aggressive turn or with someone in the back seat.
    Veteran Member Three Rings shreddykrueger's Avatar
    Feb 14 2016
    S4 Avant
    +1 for vogtland. Just refreshed with a new set after running them last for 5 years. Been super happy with the ride quality, and the customer service is solid. Blew out one a few years ago after hitting a monster pothole and they replaced under warranty without any question.
    S4 Avant (6MT)
    RCP dual pulley | AWE touring | JHM catted/baffled DP's | AEM water/meth | Ringer Stage III | RSNAV | Vogtland Coilovers | many other tings
    Aug 25 2020
    Birmingham, AL
    Quote Originally Posted by Fresh.S4 View Post
    Solowerks all day!
    I have to agree. I switched out my adjustables and installed Solowerks all around including the springs and the ride is so much better. I have about 1.5" drop. Looks and drives great!
    Dec 19 2004
    If I had to take a wild guess, KW probably makes the springs for them. I have the H.A.S from KW and they also are too "soft".
    Had the Vogtland's in my B5 S4 and liked them
    2011 B8 S4 | EPL Stage 2 | KW H.A.S. | APR Stage 1 & 2 Carbonio Intake | Borla Exhaust | Eurocode Alu Kreuz | Eurocode ÜSS Stabilizer Bars and End Links | 034 Motorsport Trans Mount Insert | Spulen Rear Differential Mount | Hartman RS 4 Wheels
    Dec 01 2007
    San Jose CA
    Great point, always forget about this. BC and Bilstein have this... KW? Who else?
    Quote Originally Posted by sepheroth86 View Post
