So I purchased this car from auction. We already replaced the starter, engine mounts, springs, and wheels that were all damaged. The amp was keeping the mmi from coming up so I have it temporarily looped until I can get this one repaired. I'm currently trying to figure out the light issues. the drivers low beam works but not the high. passenger low and high are both out but the side marker works. Both drls do not work. One fog light works on the driver's side and one reverse light. When I swapped the headlights, they stayed the same. any ideas where I should start with getting them to work correctly? Here's the log from VCDS:
Sunday,22,January,2023,21:08:23:39596
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
VIN: WAURV78T79A003997 License Plate:
Mileage: 179720km-111672mi Repair Order:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 3C 42 46
47 52 53 55 56 65 67 6C 77
VIN: WAURV78T79A003997 Mileage: 179720km-111672miles
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0140
Revision: C1000000 Serial number: 0130.05.081144
Coding: 48022000
Shop #: WSC 06325 000 00000
VCID: 72BDD2D1C4A68B5BED6-8026
2 Faults Found:
00457 - Central Electronics Control Module / BCM (J519)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 135
Mileage: 179729 km
Time Indication: 0
Date: 2008.02.08
Time: 08:58:54
00256 - A/C Pressure/Temperature Sensor (G395)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 135
Mileage: 179729 km
Time Indication: 0
Date: 2008.02.08
Time: 08:58:54
Freeze Frame:
Temperature: 8.0°C
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000056453
Coding: 26001091063CAF010000080300003D3D0F1C13880001016100 0000
Shop #: WSC 57921 001 1048576
VCID: 303918D90A2AF94B5B2-8064
Subsystem 1 - Part No SW: 8T1 955 119 C HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 050608 H13 0040
Serial number: SWFBIE 0000932
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10149871
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 J HW: 8K0 941 531 J
Component: E1 - LDS H07 0070
Serial number: 00000000000406081544
5 Faults Found:
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 135
Mileage: 179729 km
Time Indication: 0
Date: 2008.02.08
Time: 08:58:00
00927 - Terminal 30 (Right)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 135
Mileage: 179729 km
Time Indication: 0
Date: 2008.02.08
Time: 08:58:00
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 135
Mileage: 179729 km
Time Indication: 0
Date: 2008.02.08
Time: 08:58:00
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 135
Mileage: 179729 km
Time Indication: 0
Date: 2008.02.08
Time: 08:58:00
02258 - Door Opener Transmitter
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 135
Mileage: 179729 km
Time Indication: 0
Date: 2008.02.08
Time: 08:58:00
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7H0346119
Coding: 0000100
VCID: 313F1DDD0D20F04354C-8064
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 135
Mileage: 179729 km
Time Indication: 0
Date: 2008.02.08
Time: 08:59:05
Address 3C: Lane Change Labels: None
Part No SW: 8K0 907 566 B HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0040
Revision: 00H01000 Serial number: 6PZ 009 014-13
Coding: 0000004
VCID: 36352EC1E44ED77B01E-8062
Subsystem 1 - Part No: 8K0 907 568 B
Component: J0770_SWA_Slave_H01 0040
Subsystem 2 - Serial number: 6PZ 009 014-33
Subsystem 3 - Serial number: 5F17.06.0800H010003CD10258ÿ
Subsystem 4 - Serial number: D10258ÿ
2 Faults Found:
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 135
Mileage: 179729 km
Time Indication: 0
Date: 2008.02.08
Time: 08:58:59
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 135
Mileage: 179729 km
Time Indication: 0
Date: 2008.02.08
Time: 08:59:54
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Part No SW: 8K0 907 064 AG HW: 8K0 907 064 AG
Component: BCM2 1.1 H71 0134
Revision: 00002001 Serial number: 0112213318
Coding: 0106029A007A444500B000
VCID: 75B7E9CDB5C89C63C84-8020
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 2 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
Serial number: 0123456789ABCDEFGHIJ
3 Faults Found:
02901 - Lamp for Brake / Blink / Parking 2; Left (M72)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 135
Mileage: 179729 km
Time Indication: 0
Date: 2008.02.08
Time: 08:58:55
03233 - Controls for Garage Door Opener (E284)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 135
Mileage: 179729 km
Time Indication: 0
Date: 2008.02.08
Time: 08:58:58
01134 - Alarm Horn (H12)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 135
Mileage: 179729 km
Time Indication: 0
Date: 2008.02.08
Time: 08:58:58
